Results 1 to 3 of 3
Thread: Rcbb esc
    Jul 2015
    638
    Default Rcbb esc
    hi guys ,installed a new radio in my zonda that has RCBB ECS 's in it ,need to calibrate them to my new radio ,I contacted them and they sent info but not what I need ,they also said it was automatic ,is that possible ? Anyone know how to do this ? Thanks
    Jan 2011
    cq
    56
    Default To calibrate to high throttle and low need to bind radio to reciever...
    Hello,
    To calibrate to high throttle and low need to bind radio to receiver...first then hook up esc ... then unplug battery ....and turn off radio
    After turn back on radio. .. and set throttle to high. ..when hear beeps move throttle stick to low position. ..and wait for initialization. ...then unplug battery to esc and turn off radio should now be set this is sequence for most esc to set high and low throttle
    Best regards!
    Summer Xia
    7,633
    What model? They are the same as FighterCat/Flier. Turn on Transmitter, check throttle adjustment(it should be at 100%). Make sure Rx is powered (unless it has BEC), hold transmitter throttle on full, and connect battery power. Wait for the series of beeps, let go of throttle, should hear another series of beeps, done. Disconnect things and reconnect, all should be fine. Each time these are programmed they need to be re calibrated or so I have found.
    Any further issue and let me know, I should have instructions at home or on home computer.
