Page 1 of 2 12 LastLast
Results 1 to 30 of 59
Thread: P offshore scratch cat build thread
    Aug 2008
    CO
    7,080
    Default P offshore scratch cat build thread
    Few plans are out there allowing us to have a jump start on a scratch build. I came across Lonewolf (Shockerman) 8 years ago and he generously gave me his plans. I have built half a dozen different permutations of these plans and have recently scaled them to 34" and tweaked the tunnel height/width, tunnel attack, downward force from deck and angled out the sides somewhat aggressively.
    I have watched my slomo vids and seen that many cat rolls are initiated with a forward pitch and slight roll - then the water slips up over the deck and initiates the death grip. SO, I thought a slightly outward slant (not unlike a mono bow) would add lift in such a pitch/roll event and so far in the 24" and 12" it has worked great. For the 34" hull, I decreased the angle so as to not add lift to the bow, which if racing near 60, this could increase blow over potential.
    This set of plans is pretty simple and requires a good bit of patience; trial and error fitting and some design-as-you-build technique.
    Before I started adding CF rod, plate and cloth, it was pretty economical... but now its strong. I have not gotten these plans laser cut, rather I plot them, cut around the parts and paper glue them to the balsa. I use a combination of utility knife and straight edge and bandsaw.
    supplies:
    3/32" balsa sheets (6" wide by 36" long)
    1/32" ply sheets (same dimensions)
    1/4" square stock (bass)
    3/4" 45 triangle balsa stock 2x36"
    1" and 3/4" trailing edge balsa stock 2 each x 36"
    5/8" leading edge for wing (front of the tunnel)
    CF rod, 1x3mm by 36; Cf plate (1mm) and CF cloth
    CA and kicker
    West Systems epoxy (I used 205 hardener)
    US composites 2 part expanding foam (2lb/cubic ft)
    industrial rubber cement (for adding the ply skin to the balsa sheets)
    Sandpaper, block
    building board 7.5" wide, 2" deep and 36" long wrapped in wax paper
    I will be less verbose in the posts but will answer any questions that may arise.
    pic 1: dog with a boat for scale. the frame goes together pretty quickly and I recommend using a building board wrapped in wax paper. The flatness is crucial and the closer to the exact tunnel width the better. I forgot the wax paper and thus in pics 3-5 you see I used some CF strands to beef up the corner. then I covered my booboo on the tunnel side with 45 angle balsa. I got the idea from my M1 Super Cat hull.
    Pic 5 shows my motor mount CF plate - this will be designed for either twin or single. In fact, I'll be putting in the tubes and motor mounts for twins just in case I want to see how fast I can get her going.
    "Look good doin' it"
    See the fleet
    Aug 2008
    CO
    7,080
    Default framing done
    I used a fair bit of the CF rectangular rod (1x3mm) to strengthen the framing. Balsa is light but weak until you get her skinned. So, keeping with light, I reinforced each or the rear bulkheads and the rear stringers - where the open cavity will need it.
    Some cross bracing up front will keep the deck firm supported until the glue dries. I ran some of the CF rod along the rub rail to help with the shape and also provide superior strength when a fellow club member comes over for a hip check. in the last shot, you see a pretty flat, zero attack tunnel. This was a suggestion from Jay Turner, who helped design the Motley Crue. Not only does it decrease the amount of air packed in the tunnel, it brings the deck down more for increased down force.
    See the fleet
    Aug 2008
    CO
    7,080
    Default the way I skin a cat
    I like to build up the strength along the sides first. Along the back you can see my CF ride pad supports, motor mounts and/or battery trays. These were cut to fit flat on the bottom and provide chine support to the rear sides. Once I got the sides in place (balsa grain running long-ways), I sanded and controlled that the ride pad area was perfectly flat, square and equal on both sponsons. I added a little triangle to the very first bulkhead to help with the tip shape. Once I was happy in the trueness of the sponson shape, I skinned the bottom with balsa. Then sand until flat and w/o bumps.
    I always use a sanding block, not only to keep the lines straight but to keep the surfaces flat. Balsa is soft and dents easily. I also like to sand in all directions but not in circles. I was using 100 grit for shaping, 220 for smoothing and then 320 for final finishing. You don't want the balsa too rough for the contact cement used to hold on the ply skin.
    the rear is always a challenge - unless you like a flat one. I like a good bit of shape back there and some overhang is always more attractive. With stingers, you can hang them under the extension and I have created a little space for them, actually still designing them now.
    See the fleet
    Aug 2008
    CO
    7,080
    Default finishing the skin
    last few shots of the skinning process and the finished product. You can see its still a little rough - don't want to sand too much! I made a simple faux transom overhang for the time being, but have since modified it to kinda hide the rudder bracket and strut mount (for single drive) as well as make the nacelles for the stinger mounts.
    At this point I started sealing the interior of the tunnel and next postings will be the cf cloth to reinforce the sponson fronts.
    See the fleet
    Aug 2008
    CO
    7,080
    Default cf ing the sponsons
    here is the inside of the sponsons with a healthy dose of CF cloth. Also you can see the evolution of the ride pads. Original Shocker plans have the sponsons stepped, but I decided to only step the ride pads (1" trailing edge balsa stock). Here I also used a 3/4" trailing edge for a continuous spray rail (no step). The angle of the sponson bottom and steps was influenced by my M1 super cat.
    You can see I did the ply second skin cross ways - adding significant stiffness to the finish. This way the epoxy will not soak in as much and the skin has a tougher shell.
    See the fleet
    Aug 2008
    CO
    7,080
    Default stinger nacelles
    This is pretty much how she sits today. got the stuffing tubes installed, SV27r stingers and wire drives installed. I had to disassemble the faux transom but deciding and designing as I build is my style. I wanted to allow for either/both twin and single motor applications. The rudder can be inline or offset (just add the offset bracket). I wanted to get these twin drives finalized before skinning the deck.
    See the fleet
    Sep 2012
    Tg
    1,439
    CA
    4,407
    Jesse, You got talent and skills, my friend.
    Government Moto:
    Aug 2008
    CO
    7,080
    Quote Originally Posted by domwilson View Post
    Thanks man! Hey buddy, sorry I ain't got no kickin groves with this thread... Maybe I will when I maiden voyage this sexy cat. Hope you doin well!
    See the fleet
    Mar 2011
    BC
    7,630
    Very nice bottom on that cat Jesse. She should be a good runner. One day when I have the time I'll scratch build one.
    CA
    4,407
    Quote Originally Posted by Jesse J View Post
    Doing good. Setting up for another speaker design. Need your tunes! I've been buying the CDs.
    Government Moto:
    Oct 2008
    CO
    9,488
    Looking good as always Jesse !
    Aug 2008
    CO
    7,080
    Ok, Jim the legend convinced me to finish this bad kitty as single motor and get her on the water... stay tuned.
    See the fleet
    Jun 2017
    TX
    30
    Hey Jesse, did you do any figuring for the ride pad width and where you put the steps or just figure it out as she goes? I agree with Mr. Jim, let it stay single motor so one day we can wish to keep up with it.
    Aug 2008
    CO
    7,080
    Hey Cory, figuring, yes. I looked at my M1 Supercat a lot. P offshore - open class. hopefully in a month or less.
    See the fleet
  16. #16
    Aug 2008
    CO
    7,080
    Well, so still not done, but some updates.
    Now direction is to battle the twin velos in our club.
    Set the motor mounts in jb weld and skinned the front sponsons deck in 3/32" balsa, while the rear sponsons deck in 5/64" bass wood. Gonna run two proboat 1500kv motors and their esc's on 6s2p. Will need external bec, but should not provide any smoke, just magic.
    Props: first pair 442, with 45mm on hand in case we need more blade.
    She is up on the shelf curing now, pics to come.
    See the fleet
  17. #17
    Sep 2011
    Tx
    287
    Where the pics Jesse? I didn’t get that rigger.
  18. #18
    Dec 2013
    az
    1,228
    6s wouldn’t be legal in p offshore.. but yes.. pics and video please
  19. #19
    Aug 2008
    CO
    7,080
    Ray, thanks for the comment. The twin 6s is intended to race a club member and his twin zelos (not in any specific class). As you can see there is copious amounts of space, which equals flexibility. I'll probably add a center motor mount for either p lim offshore or full p offshore.
    I'll get some pics up this weekend.
    It's kinda slow right now, but I'm remembering how nice it is to work with wood!
    See the fleet
  20. #20
    Dec 2013
    az
    1,228
    U can run twin in p.. I’m actually building a cheetah right now for p.. with twin 3674s.. I like ur build.. keep it up
  21. #21
    Aug 2008
    CO
    7,080
    Good point Ray, I could easily drop in a couple p motors and smoke some competition. The most important part for me now is to GET THIS KITTY WET!
    Here are a few pics of motors and esc placement. Those are the old proboat 1500kv black jack motors and esc... don't tell anyone, but you can run em on 6s if you use external bec.
    This design tends to render the space kinda tight... NOT! Tons of room...
    See the fleet
  22. #22
    Dec 2013
    az
    1,228
    Nice!! So do u tape whole top part on?? How do i get to motors if not??
  23. #23
    Aug 2008
    CO
    7,080
    Patience my friend. I'll make progress and share the pics.
    See the fleet
  24. #24
    Aug 2008
    CO
    7,080
    Default Skinned up
    During the sleepless moments at night, I settled on the following technique:
    The rear portions of the sides are covered with 3/32 bass sheets. I added a 4" strip of heavy glass to the underside of the sheeting. As well as sealing the wood, this hid the glass so I didn't have the hours of sanding required to get a paint ready surface. Also, this leaves me the option of having a nice birchwood deck, unpainted. Now it's super strong, lightweight and smooth.
    I did a similar technique with the hatch, but with cf cloth. I learned with this part I didn't need to lay the cling wrap underneath... that's why it is irregular looking. Still need to add a canopy to the hatch... need more sleepless moments to land on a design.
    You can see there is still plenty of room to get in and service or remove the motors. If I do install a single motor later, I'll leave the twin mounts in.
    See the fleet
  25. #25
    Aug 2008
    CO
    7,080
    Now I have my rudder installed. Added a 3/16" cf plate inside and a layer of cf/Kevlar in the rear bay.
    Realized I don't have a servo bracket... but Steve did!
    See the fleet
  26. #26
    Aug 2008
    CO
    7,080
    Now to make the hatch flat with the deck.
    Here I have epoxied a sheet of 1/32" plywood and a little weight to entice the hatch to assume the position while the glue cures.
    I'll be working with Travis on a custom canopy with his mad carbon fiber skills.
    See the fleet
  27. #27
    Oct 2013
    la
    8,740
    Nice! Do the sides come off for easy access to the motors? That would be a nice touch.
  28. #28
    Aug 2008
    CO
    7,080
    Nope, sides are fixed... for now.
    I can always add motor hatches that would screw down and be semi permanent.
    See the fleet
  29. #29
    Aug 2008
    CO
    7,080
    Default Canopy
    Working up a custom canopy. This is sandwiched 2" and 1" foam board, cut on the band saw following a design I drew in graphics software.
    These are 5 min epoxied together and now the sanding begins.
    Once I get the shape I want, I will coat with epoxy then send off to Travis for a carbon fiber shell from this mold.
    See the fleet
  30. #30
    Dec 2013
    az
    1,228
    Looks good man.. can’t wait for u to get it running
