Results 1 to 3 of 3
Thread: v3 rudder hardware fit on v2
    Mar 2016
    wi
    2
    Default v3 rudder hardware fit on v2
    I just got the miss g v2 and want to put all the v3 offset hardware on to my v2. But with the ose upgraded strut. I love the look of all the black and want the offset will it work
    Are you still running stock electronics?
    BJ42'' / Miss Geico 36'' / TFL Hydro 35'' / Retrieval boat 30'' Tug
    Make sure you check out my Youtube channel -----> shorturl.at/ntFQ7
    Jul 2016
    4,131
    You might need to massage the mounting holes in the hull a bit and modify the length of your flex cable depending on the final location of the new strut. Rudder push rod length will probably change, as will the angle. It's all very easy RTR modification task type stuff that you should be able to handle.
