Results 1 to 20 of 20
Thread: What esc to use
    Mar 2015
    on
    213
    Default What esc to use
    Hi like to know what is the recommended speed control for castle 1515 1y 2200 kv and also the timing
    Sent from my Nexus 4 using Tapatalk
    Oct 2013
    la
    8,740
    That depends on what it's going in and how many cells. You can get away with a Seaking 120 set at 15 degrees timing if your not pushing it real hard and running on 6s. More details will net a better answer....
    Mar 2015
    on
    213
    I am using 2 x 2s 7.5 v 6800mah and 6200mha
    Oct 2013
    la
    8,740
    Ok. I give up.
    Mar 2015
    on
    213
    the boat is an insane fe 30 and goin to get m445 prop with those batteries from posting 3
    Jun 2007
    5,190
    You may have an issue...are those batteries from the same manufacturer? and also not advisable to run batteries with different mah outputs in series.
    Douggie
    Mar 2015
    on
    213
    i have st of them 2 the same 2x 6800 and 2 6200
    Dec 2013
    az
    1,228
    just get a seaking 180 you will be safe
    ca
    6,963
    We designed the FE30 as a P-Class or P-Ltd Class heat racer (4S2P or 2S1P x 2 or 4S1p)
    If you're using the 1515 1Y P-Class motor you can't go wrong with the T-180 (with a little mod to the waterline direction) or lately I've been building them with the Swordfish 220A.
    Best battery setup for full P is 4S2P 4000mah [e.g. 2 X 4S 4000mah packs]. Just DO IT - don't use the packs you're mentioning. With 4S2P you'll have plenty of headroom and enough runtime for a mill + 6 laps on a 1/6 mile course (which is a bit over three minutes at P speeds if you're just sport running) AND the weight will keep the boat planted.
    Y winds can , if not heavily loaded, use high e.g. +15 degree timing or anything close.
    Here's a bunch of FE30's with T-180's and near the last pages 220A Swordfish ESC's
    https://forums.offshoreelectrics.com/...at-RCBOATBUILD
    Mar 2015
    on
    213
    Hi I only have these I just got them not long ago and budjet iks limited I will have to use those batt are AGA power 2s1p 7.4 6200 mah 50 c and the other set are AGA power 2s2p 6800 mah 70c and I got them before Xmas I will have to try these until can afford other one and thank you for all the reply
    ca
    6,963
    Quote Originally Posted by langevn View Post
    Keep in mind that both the T-180 and the 220A Swordy have been known to have rather overprotective LVC's SO you'll likely be encountering this issue using batteries that have less capacity that the fairly amp hungry 1515 1Y like to feast on. Starting with a slightly smaller prop like a de-tounged X442 will consume a little less power but still give plenty of speed
    Mar 2015
    on
    213
    I don usually have the LCV activated I use external 6.6v life batt for my cervo
    Mar 2015
    on
    213
    And also I race in the D1 impba so some rule to apply with some voltage and amp
    2,913
    As far as I know D1 (Northern Lights) have NO limits on ESC's
    There are limits on Max volts, and Max mMP's (in battery capacity) allowed on board.
    Also your length limits per class.
    9,402
    Go smaller on prop like propchopper said. A detonged 442, maybe m440 3 blade thinned.
    2,913
    In "P" Sport Hydro I run
    Neu 1515 1Y 2200kv
    4S2P 5000mAMP 65C packs
    240A ESC - 15 timming
    440/3 prop
    Mar 2015
    on
    213
    Sorry guys I have only these pare battery AGA power 2s1p 6200mah 60 c and also 2s2p 6800 70c i habe no other to use and also have already have coming m445 and m545 prop if this motor not going to be useful to hen will use the other one leopard 4074 2200kv
    Jun 2007
    5,190
    I think you really have to look at the suggestions that have been made...your castle motor is fine ....your batteries are very suspect...your props are dubious at best. I know you are on a strict budget, but a little caution with your setup will provide you with fun and not an expensive mistake. It is better to spend your money prudently rather than "I will give this a go attitude as this I what I have"....just my two cents.
    Douggie
    Mar 2010
    ME
    3,438
    That leopard your talking about is basically a knock off castle that is the same exact specs as the 1515 1y castle lol
    Mar 2015
    on
    213
    Thank you
