It's FINALLY here guys!!
This is being revealed at the IHobby Expo today as I post this (9:00am Central)...
Welcome to a the NEW AGE of RTR Racing boats!!
AquaCraft UL1 Superior
Here are the specs:
AquaCraft UL-1 Superior Fast Electric Hydroplane
A Michael "Grimracer" Zaborowski Design
Street price around $330
Hull:
Fiberglass shoebox with drop tub center
ABS cowl and hatch
RACE inspired tape down hatch
LIPO READY and RECOMMENDED
Aluminum hardware
.150 cable with .187" stubshaft
27" long
4+lbs RTR
New aluminum motor cooling jacket
Available in a new cooler yellow, red, orange and white
Radio:
2.4ghz Tactic System
Standard Tactic servo
Antenna-less RX (very cool and very solid performing)
Motor:
AquaCraft 3656-2030
6 poles
Weight: 212g including male and female connectors
Input Voltage: 7-18.5V
Max. Constant Current: 50A
Max. Surge Current: 80A/five seconds
No Load Current: 5.0A
Motor Diameter: 36mm
Motor Length: 56mm
Shaft Diameter: 5mm
Shaft Length: 15mm
kV Rating: 2030 rpm/V
ESC:
Length: 3.25" (83mm)
Width: 1.5" (38mm)
Height: 5/16" (17mm)
Weight:3.8oz (109grams)
Wire Gauge: 14g
Battery Connectors: Male Ultra Deans Plugs (2)
Motor Connectors: 4mm gold plated bullet connectors (3)
Input Voltage: 12-14 NiMH, 4 cells LiPo, 8-20V input w/o BEC
Output Current: 60A continuous maximum 72A surge maximum
Max Output Power: 720 watts
On-resistance: 0.003 ohms
Operating frequency: 8kHz
BEC: 5.2V/2A
Stutter Bump Voltage: 12V
Low Voltage Cutoff: 11.6V
Thermal Cutoff: 110C
Timing Angle: 10 degree
