Saw one run at the club lake today, 2 x 3S, sharpened props. Very nice. The owner is very happy so far. The boat got a lot of attention.
I don't know if I ever shared this video.
https://www.youtube.com/watch?v=1QOvs-t2OnQ
Rafael Lopez
Product Developer-Pro Boat
For what you were doing in the video you posted, the adapter will work fine. That's the moderate way of running you can do with the adapter, which I mention in our video. If you are going to go do laps for 4 minutes straight, without ever letting off the throttle, you will heat up the adapter and it will come undersold.
With 4 packs, each ESC works better because the amperage is dedicated to each ESC, so things run cooler. Your packs will stress less that way.
Rafael Lopez
I wanted to share with everyone that I was able to beat and set a new NAMBA 2 lap Q-cat record with this boat. It is stock other than sharpened and balanced props. Previous record was 2 laps in 0:33.8. I ran a 0:31.2. My unofficial fastest was 0:30 but it didn't count because I had over 10,000mAh to each ESC. Here is a picture of my unofficial run where my fastest speed was 63 mph. Again, this is all stock, including timing.
Rafael Lopez
THIS IS SO AWESOME!!!!! rtr boat....bam!
Going back tomorrow, shooting for a 0:29. I just have to tighten up my turn around the right buoys. If I can unofficially get a :30, I know I can officially get a :29 just by tightening my turns. It's amazing how well the boat handles the turns around the buoys, only letting off to head in to the turn. You can get on it and fling the boat out of the corner at full throttle.
Rafael Lopez
Makes me want to stop my v-hull build, sell everything and order one of these!
NEVER SATISFIED RACING
Fine Design 32 V-Hull 4082+6s
Really love this cat thats my next rc purchase
Will the Zelos handle this sort of chop? This is the reason I can't really do any WOT runs with the voracity. Just short burst from time to time.
Mount the packs all the way forward and drop the struts 2mm, maybe 2.5mm. But I've never ran in water that rough, other than with the Zelos 48.
Rafael Lopez
Other than having exceptional turning at high speed capabilities, what other benefits does the twin 36 have when compared to the 48? They seem to have relatively the same top speed. Is the hull of the 48 just as thick as the 36 because I've seen some having cracked their rockstar hulls which is same as the zelos. Do both boats handle waters not as rough as posted above the same or would the larger be less likely to want to flip when weight is placed towards front? I plan on running on the river where I'm located which is relatively smooth at times and can't help but wonder how a big 48 would be compared to the 36 for overall reliable fun. We never saw any hype with the 48 like the 36 has turned out to be. Already just as many videos of the 36 online as the 48 thats been out for 6 months.
Yeah that's what I'm dealing with here, until I can get a canoe or dingy, the river is the only calm spot but then again like I mentioned, I'm reluctant to even go get it, 3ft shoulder drop followed by an immediate 50ft. Not my kinda San Andreas rescue. I'm sure the Zelos will be a blast. Have we had multiple prop changes as yet on the Zelos?
CONGRATS Rafael and Darin too! I wish there was some organized racing closer to me.
I got my Zelos 36 today. Looks really nice & the hardware looks really good too. Im glad Proboat has been doing good things with their models. I was happy to see the in hull water pickups & nice rudder setup as well.
Im curious about the esc program card. Looks just like a turnigy/seaking/hobbywing esc program box. Will any of the esc programs cards I mention that look similar work all the same on these esc's?
Also is there enough room to put two 5000Mah 4s 14.8v or two 5000Mah 6s 22.2v packs under the lid & power each esc directly from each pack? Meaning not using a harness. I haven't measured yet so I thought Id ask. Might have to mount in sponsons?
The props look like x442 pair replicas. Anyone try anything else with the stock setup (motors & esc's) other than prop sharpening & balancing?
Also would a couple 40mm by 74mm with cans fit inside there okay on stock mounts?
Raphael is at an event with the zelos right now. I'll answer what I can.
The hobbywing Seaking program card does work, the marine version does. The car version I had no luck.
Stacked on top of each other, (4) 5000 3s won't work. So for sure 4s won't work. But smaller mah (4000ish) 3s will work. Now I think you can put 4 batts flat....another pair to the front.
I haven't tried any different props yet (well I did but it flipped in quick order...needs strut adjustment) I do havens few things to try if the weather clears up.
I wouldn't put much heavier or longer motors on the stock mounts without some rear support. They are strong but a longheavy motor may stress the mounts.
It will handle moderately rough water on 4s. I wouldn't run it on 6 s in rough stuff unless you have a way to get it. Also if it's rough enough to unload the props constantly then I definitely wouldn't for fear of motor damage.
There is plent of room for two 4s packs to power each esc seperately
Kfx, does dual 4s overheat anything? I assume motor and ESC would need upgrade?
Rafael Lopez
Hey Rafael,
2 4s packs total I'm referring to.
You can connect 2-6s to each ESC individually. The lower the voltage, the less amps each motor will comsume. Also, everything will run cooler with less voltage.
Rafael Lopez
So its obviously more efficient to run four (4) 3s battery packs total? Two (2) 3s packs in series for 6s power on each motor?
Whats the little "black" buttons right next to the esc on/off buttons for? I couldn't find that in the manual, so I thought I would ask.
Will four (4) 6s battery packs ran in parallel fit under the canopy?
I have to still purchase batteries, and would like to get an idea of what kind and how many.
What quad charger would you recommend?
With fast strait runs and corner drifting, and just fast fun boating period, how much "average" run time can a person expect with "four" 3s batteries at 5000mah each? 5 minutes?
Thanks in advance for the help.
P.S. Why would anybody want to run this boat on 4s? I'm not trying to sound ignorant, I just don't know.
They say pictures are worth a thousand words. Notice the speed difference between running 4 packs and 2 packs. A lot of your answered are in these pictures. This video will explain more as well. http://youtu.be/yxKhCWo6NVY
Rafael Lopez
Thanks for the pics there Rafael. Im curious why 4 packs at 22.2v vs 2 packs at 22.2v would give you faster speeds? Its only 2.4 Mph though. That could just be variations in water conditions or wind. I'd think the extra weight would cause it to be a little slower if anything.
So my next question is are 3s 5000Mah 11.1v packs the largest that will fit under the lid on the trays? I was thinking of ordering a couple of 5000Mah 14.8v 4s packs and power each ESC directly with no extra crossover plugs.
So far I have two 7.4v 90C 7500Mah packs Ill use for 14.8v & two 11.1v 65C 6000Mah packs for 22.2v
Im still waiting to go run mine I got it this Saturday. I have had time to go over it in depth. I found the prop shafts where they solder to the flex cables are a little bent. It made it very difficult to remove the cables when I inspected the line for lubrication. Also the rudder cable on the left side must have been gripped with a pair of pliers when they put the ball end on it. You could see and feel where the pliers slipped and made a groove. That was preventing the cable from moving as it should. Plus the coating on the wire/cable is coming off easily. So I added a little mercury teflon marine grease on them when I put them back in to help the slide factor.
In the mean time, patiently waiting.
That's a beauty, can't wait to get mine end of the week hopefully.
Rafael Lopez
Thanks for the info and tips on the batteries Rafael. Yes on the rudder push pull system sore marks on the plunger. The marks were on the steel shafts part that goes in & out of the mock up hydraulics.
I'll get some pictures of her on the lake soon. Photography is another hobby of mine so it's fun to run my rc & get pictures too.
Well Raphael can't control everything lol. If they were all hand build by him I'm sure they would all be perfect, but unfortunately he has a life and can't build them all for us so sometimes things slip through the cracks . Once you run it, your going to fall in love with it :). I know I did. All of my other boats are mad at me right now because they haven't been getting any attention lately. I did finally bring another boat with me yesterday but just to maiden it lol.
I'm sure he would. I don't post this stuff to complain. I figure since someone from the company is here and might see a post. That maybe they would have some clout to mention these things to production to make sure little quirks like this could be avoided. Long ago one of my past jobs was working at a boat factory for real boats. So I know it can be valuable quality control.
I can't wait to go run. Weather has turned cool again here.
