Results 1 to 2 of 2
Thread: Mini Z cat tested ,..Sorta
    NJ
    1,322
    Default Mini Z cat tested ,..Sorta
    well my 10X10 pond in my back yard finally defrosted so i tried my mini Z cat in it...
    the boat is slow much slower than i expected But i did try the 3 blade prop 1 size down from the largest from the optional prop kit and it came alive it got a little faster but nothing to jump for joy for.... I have the hop up motor i can drop in but i am thinking that my 10X10 pond is to small for the boat and it may not be getting up to top speed.
    Well i have to bring it to a big pond to test it out one day...... A lipo would be sweet in it though.
    WWW.PPRSLOTS.COM
    St
    513
    what size are the shafts for the motor and the drive shaft.........i found an old toy boat i had from when i was a kid.....threw some leftover parts and what not commin a long nicely but i want to use one of those props and wanted to know if it was real small or if its the same size as an 05 car motor shaft?? thanks
    ps this used to be just a little plastic hull and im making it r/c.... should be funny i think its only 6 inches long
    60% of the time... it works every time!
