Results 1 to 8 of 8
Thread: SV Upgrade
    Nj
    4,735
    Default SV Upgrade
    I ran into a little bit of luck when I won the auction for the inline hardware. The guy also had listed a CC Cuda 80 with the water cooling installed pluss a Feigao 8XL with an OSE water jacket. He had about 10 runs on it. Listed for 150. Smokin deal I thought. Well no one bit.... . I tossed him an offer for 135 delivered and he bit. What you see hear is just that. I cut off his deans. I didnt like the look of the solder joints. The motor end has them big 6mm bullet conectors. The joints looked fine. I tossed in a hextronic 23 volt Ubec I had layin around and there she is. I will be gettin just over 29000 rpm with this setup on 12 cells. Yes I will run 14 also. I will be on the water with this and the bullet Monday. Look for the videos late in the evening:D.
    [IMG]
    May 2007
    co
    1,973
    Default horsepower junkies
    :p what your bullet wasnt fast enough? so now you have a smaller boat with more power! :rolleyes: nothin wrong THAT!!!! try a X438to start those motors like the small diameters than maybe a 640-642
    Nj
    4,735
    Welp for now I have the stock prop on it. The only smaller props I have are the 42mm cf on the bullet and a 40,, cf in the box. Believe it or not the Sv is quite bigger than the bullet. It has way more freeboard and its longer by 2 inches almost. One of them will be going on the market by the end of the week. I only need one fast sub 30 inch mono. To complete my collection I need the following boats A Fast 25 to 27 inch mono. A 30 to 35 scale looking mono(Triton or Rio). I am getting a Jolly Cat, and last I want a Micro Hydro. That would make the perfect collection for me. Maybe down the road I will pick up a Team lindaneu rigger. They are the only one I seem to like the looks of.
    May 2007
    co
    1,973
    oh sorry! I thought I saw the bullet was 33" inches some were! I tested my hydro with an 8xl x445 motor came back 150 degrees It was flyin though! I have a heavly modified X 645 I want to try ,test tomorrow!
    Nj
    4,735
    Man I am so chompin @ the bit to get back out there. I fight off the go feaver and remember every thing...LOL.
    154
    here is what fe cal says x632 42.34mph 49.38 amps and 4 minutes run time. this is for a hacker 8xl but the feiago shpoul be pretty close and the feigao has another 100rpm/v over the hacker.
    St
    513
    nice work........ should be sweeeet.
    60% of the time... it works every time!
    St
    513
    how did you mount the speed control to the motor..... wont that build more heat or no
