Results 1 to 14 of 14
Thread: DF 26 Suggestions
    Dec 2007
    170
    Default DF 26 Suggestions
    I'm thinking of building a DF26, I built a DF22 for my first boat and am very impressed. Anyways, I'm still quite the noob since I built my DF22 last spring, so I was wondering if anybody had some suggestions for motors, hardware, lipos, etc.
    My thoughts were 9xl, 7.4v lipos w/ around 4000-4500 mah, Stinger strut, carbon prop, around 1.5ish inches, ESC not chosen.
    All advice is welcome!
    Mar 2008
    Au
    806
    I'd go for an 8xl and use the solinger mono hardware, a x440/3 prop works great with this setup..
    Heath
    Fr
    1,300
    9XL would be perfect for the 29.5" under 4S bit heavy for a 26" IMO!
    9L under 3S would be better I think! two 3S 2200mAh in parallel
    Emmanuel
    I'm french but I doubt I really am!
    http://pagesperso-orange.fr/pleindetrucs/
    Aug 2008
    253
    you could get the super v combo
    SUPERVEE 27 37'' TWIN CAT
    Apr 2008
    Ql
    393
    Hey OJ
    A fast and reliable setup would be the Aquacraft Combo on 4s and as Heath said the Solinger gear would be perfect for that hull.
    We run the same setup in an Oval Master 26, we normally run either an X440/3 or an M445. But if you were looking more for runtime then speed you could go with maybe a M or X442.
    Jimmy
    Come to the FASST side
    Dec 2007
    170
    Faster is good. Thanks for your advice! More is welcome, you can never know enough in this hobby.
    Sep 2008
    OZ
    2,865
    i have a 25" copy runs a ammo2300 on 4s runs 43mph setup for oval
    Dec 2007
    170
    What would be a good choice for turn fins? I was lookin at the OSE ones as probably the best choice.
    Mar 2008
    Au
    806
    they'll work fine :)
    Dec 2007
    170
    What kind of lipos do you guys reccommmend? I was looking on RC lipos and there were a few Poly RC lipos that caught my attention. They were the 7.4v and 14.8v 4300ish mah batteries, but they were in both the High Performance series and the Expert series. Which series is best? I want to upgrade to lipos, so I'm new with them.
    Mar 2008
    Au
    806
    the elite 5300's are a good choice for the money
    Dec 2007
    170
    What about the 4500s? They're alot less money, or is 4500 not enough?
    Apr 2008
    Albuquerque
    81
    On my DF 26, I'm running a Fiegao 9L, with this hardware, Castle Hydra 120, 3s2p 2500 lipos, and m535/3 prop. Also a SV27 turn fin and trim tabs. IMO the OSE turn fins are longer than necessary. The boat is very fast and turns like it's on rails!
    Mar 2008
    Au
    806
    yeah 4500's will work, but if your racing ur better off with a higher capacity
