Results 1 to 9 of 9
Thread: Trouble finding smaller 3/16" counter rotating props
    Dec 2011
    Fl
    10
    Default Trouble finding smaller 3/16" counter rotating props
    Do these exist or am looking for a ghost? Have twin Leopard 2860's/1690KV w/ twin Aquastar 120 esc's and a 4s battery. It has twin surface drives with 3/16" flex shafts. Am thinking I need smaller pitch and diameter to work properly with this oddball set up. Not really looking for high speed here. Any idea's are appreciated.
    Wa
    5,905
    Smallest one I know of I think is a x440 in octura not sure of other prop makers. You might check prop shop
    Sent from my SM-G900T using Tapatalk
    Billy Graham
    Dec 2011
    Fl
    10
    Thanks for the quick reply. I am finding the same. What is the prop shop?
    Wa
    5,905
    They are in england but I think Dasboata on OSE who balances props orders from them sometimes so maybe he can help you
    Billy Graham
    Nov 2008
    Ql
    3,169
    Steve here at OSE has Octura X437/3 blade, & 438/2 blade in the CNC range. both with 3/16" bore.
    Oct 2009
    MI
    6,192
    Octura makes a 536 but not in counter rotating.
    Propshop will deliver to the states.
    http://www.prop-shop.co.uk/
    Noisy person
    Dec 2011
    Fl
    10
    Thanks for the replies. I was not sure if the X437/3 may be to much to swing. Thanks again.
    Nov 2008
    Ql
    3,169
    You can usually run bigger props on motors in a twin set up than you can on the same motor in a single set up in the same size or even slightly larger boat.
    Also, a couple of strokes with a file to take half a millimeter off the tips & you are down to a 36mm prop if they are drawing too much load.
    But you are only spinning at 25000 revs. Depends on the type & size of boat.
    Any pics?
    Dec 2010
    NY
    3,119
    Thanks Jim I am a prop shop dealer but you are probable best off just ordering them from there website http://www.prop-shop.co.uk/index.php?section=home
