If you run an unbalanced prop it's going to cause issues for sure. Not being sharp is another no no. More load on the driveline.
I've run .187 flex in everything I've built and I can assure you that you are not past its point of failure due to power. Do you have at least a 3mm between the drive dog and strut? If not that can cause breakages. Are you lubing after every set of batteries? That needs to be done. Post a close up of your flex and where it's failing.
