Results 1 to 6 of 6
Thread: measuring pitch
    Aug 2012
    az
    47
    Default measuring pitch
    So im new to measuring pitch. In other threads guy talk about measuring at (x)degrees to make the math simpler. So what is this in reference to? I had plans to make up a pitch gauge. Similar to voodoos. But i need to understand how thay work.
    Nov 2012
    De
    356
    This is referring to the number of degrees the blade is turned, 5,10,15,20,25,30 degrees. During the turn the gauge measure the drop in inches on an area of the blade, TE refers to trailing edge, COB centre of blade. Taking the measurement you look up on a chart for the numbers of degrees and you get the pitch for that area of the blade.
    The larger the number of degrees the larger the area measured on the blade.
    Dec 2010
    3,119
    Quote Originally Posted by StevenBryant View Post
    Yup what Steve said I would say just buy one !!!
    9,402
    Subbed for more possible info.
    How many different pitch gauges are there besides the old Hughey, Voodoo and ????
    Dec 2010
    3,119
    I get some made for myself,,that are very easy to use ,, there are woods. speedmaster, I also have a German,, made gauge,, I am sure there are plenty others !
    Nov 2012
    De
    356
    I use the Orlic gauge, great little unit
