Results 1 to 17 of 17
Thread: Collett loose
    Oct 2015
    313
    Default Collett loose
    hello men
    I just received the Voracity
    Did not know better but, I took it out on its maiden voyage with out doing a check list and it lasted about 2 minutes before the collet spun loose.
    I hit reverse which spun it tight slightly enough to get it back to shore.
    I tightened the collet to what seemed appropriate and the same thing happen.
    seems I don't know what I'm doing with the collet and know the flex shaft looks twisted.
    Help
    AZ
    8,010
    The cable is toast unfortunately. It is important to have the collet very tight, especially on a new cable and collet. Use wrenches which fit the collet well - not cheap crescent wrenches. The wrenches should be at least eight inches long in order to apply enough torque.
    Oct 2015
    313
    Crap!
    It was loose from mfg
    How do I remove it for replacement?
    Oct 2013
    la
    8,740
    You will probably have to cut with a dremel. You should check it just in case. Also, when you get a new cable, make sure you clean the grease off the shaft before it enters the collet. I use a rag and brake cleaner and slowly push it in as I wipe it.
    Mar 2009
    OH
    1,585
    Quote Originally Posted by Crash View Post
    Crap!
    What do you mean loose from the manufacturer? Did you never take it apart and grease it?
    Oct 2015
    313
    no sir I did not grease it.
    The owners manual says to grease after 30 minutes of run time not out of the box. It should be ready to go. RTR
    Oct 2015
    313
    Thanks for the advise
    I went back to the boat, cranked the collet on like I meant it this time and went back to the pond with my boat.
    It ran fantastic this time. Went threw 3 sets of lipo packs. Everything went great this time, the boat is fast and fun.
    Turning is something new for me on a boat, still learning to drive it essentially.
    I've been into RC for 15 years, BL for 5 years. but, this is my 1st boat.
    thanks for any help men.
    Mar 2009
    OH
    1,585
    Always check the collet ands grease it. about every 3 runs. after your day is over take it out and wipe it down and put it aside. Maintenance is a big thing in the hobby.
    Oct 2015
    313
    Quote Originally Posted by photohoward1 View Post
    Thank you.
    Oct 2015
    313
    many learning moments in the FE Boat Hobby
    I was out to the pond today and for better handling I moved the batteries forward in the trays.
    The boat handled real nice, noticeably slower but after a high speed run yesterday into the wind it took off like a airplane, I learned my lesson.
    The battery leads got so hot they came loose on one lead.
    Everything else is cool...ESC, Motor
    Batteries and leads get hot or very warm to the touch.
    what does it mean when everything is cool but batteries are hot....
    Newbie
    Nov 2012
    De
    356
    I would say you are running the cells down too low, personally I take my cells down to around 30% capacity on a run, this keeps the cells in best condition
    Dec 2009
    TX
    2,041
    Looking at the picture you posted, the cable is unwinding. As Fluid stated, you need to replace the cable before it causes more issues.
    Dec 2009
    TX
    2,041
    Newbie
    Use the search tool. There's already a couple good tuning threads for this boat.
    Mar 2009
    OH
    1,585
    What kind of connectors?
    Oct 2015
    313
    I am using a set of venom batteries that came with every connector but the 5mm bullets
    so I had LHS make up a set of jumpers from deans to 5mm bullets to match boat.
    yes the deans is what got hot enough to melt the solder.
    turns out not a great idea, I really wish my LHS had some knowledge about boats but, they do not. This is not 1st bad idea they had.
  16. #16
    Mar 2009
    OH
    1,585
    Deans Bad! 5mm good.... learn how to solder and ged rid of the deans and the jumpers.
  17. #17
    Oct 2015
    313
    http://vid216.photobucket.com/albums...MOV_2792_3.mp4
    this is when the flex drive came off.
