Hi All,
My turnigy 120 ESC in my 4S outboard is no longer working, just wondering what others are running with a similar setup? Motor is a UL1 on a Lawless leg Vision 20 hull.
Thanks in advance
Wayne
Hi All,
Thanks in advance
Wayne
Wayne, I am using the UL-1 motor/esc combo on 4S in my 20 Vision with an O.S leg...runs very good...fast! No problems with the UL-1 esc...
Check out "My Gallery" for pics of my Vision...
-Kent
"Will race for cookies!"
IMPBA D12
My Gallery: https://forums.offshoreelectrics.com/album.php?u=1738
Is this the one you were referring to Kent? Is there a programming card required?
http://www3.towerhobbies.com/cgi-bin...?&I=LXVSV4&P=7
double up
That is it...no program card needed...just need to dial in your throttle trim (I use Futaba radio...throttle dialed to 22 I believe)...just change batt. connectors to 5.5 ose bullets. Some also change motor wire connectors (I personally do not...just make sure they are crimped tight)...
IMPBA D12
Its great that they are waterproof as well, I run mine outside of the sealed radio box for several years with no issues, and its been upside down numerous times.
Grand River Marine Modellers
