Page 1 of 2 12 LastLast
Results 1 to 30 of 33
Thread: X-Cat Twin
    Jun 2015
    Tx
    87
    Default X-Cat Twin
    Here's my latest project.
    Converted Motley Crüe X-Cat with custom made engine stand offs fully adjustable.
    6,191
    Have you run it yet? That's just really cool.
    Noisy person
    Jun 2014
    1,516
    DAM! I've been wanting to do something like that. Looks like the motors look pretty scale with the hull, nice job!
    What motor/esc/battery setup are you running? Can you post some pictures of the interior?
    NEVER SATISFIED RACING
    Fine Design 32 V-Hull 4082+6s
    Jun 2015
    Tx
    87
    Thanks yea I've always wanted to build an X-Cat so I did it, will be building another and probably selling this one.
    Jun 2015
    Tx
    87
    Quote Originally Posted by Tamelesstgr View Post
    Twin 2600kv 4s engines with twin Turnagy 120 ESCs with twin 5000 4s Revolectric battery's.
    7,279
    Have you bat-tub'ed it yet....the CG should be very interesting!
    Jun 2015
    Tx
    87
    That I have not, gotta get everything situated inside then I'll play with CG.
    Jun 2014
    1,516
    Any idea what it might run on the water?
    7,279
    Should be cool!
    Jun 2015
    Tx
    87
    I'm thinking in the 50-60mph range once I change the plastic props out for some good ones, the plastics won't handle 4s for very long and flex to much anyway.
    Jun 2014
    1,516
    Are you set up with counter-rotating outboards? Are those the TFL units from HobbyKing?
    I would have liked to build one that would go 40'ish
    Jun 2014
    1,516
    or is this the unit you are using?
    http://www.hobbyking.com/hobbyking/s...dproduct=66147
    Jun 2015
    Tx
    87
    That's the ones, yea you can counter rotate them and I might just do that if I can find a l/r prop that will fit.
    9,401
    Quote Originally Posted by DCMW View Post
    And cable!
    Jun 2015
    Tx
    87
    And cable!
    Ah that's right, I can make a right hand cable for it:)
    Jun 2015
    Tx
    87
    Pics of inside electronics.
    Oct 2008
    9,488
    This is so cool !
    Jun 2014
    1,516
    Was it difficult feeding the wires through the double hull?
    Jun 2015
    Tx
    87
    Wasn't the easiest task but that's what good little needle nose pliers and some patients plays a good part:)
    Aug 2008
    7,080
    That is the tightest x cat model I ever done saw! Glad to have seen in person!, steering is rock solid!
    "Look good doin' it"
    See the fleet
    Jun 2014
    1,516
    Part of me wants to see a running video cause it will be awesome.
    Part of me doesn't want to see one, because I'm going to want one for sure.
    Jun 2014
    1,516
    I'm curious about the props, what size if the propshaft? 3/16"? Kintec and OSE have nice CNC units you could try.
    What is the connection at the motor shaft and cable? Is it a collet or grub screw type linkage?
    Jun 2015
    Tx
    87
    I believe it's a 4mm shaft.
    Yes motor is coupled to shaft with a collet that has 2 set screws on the cable and the engine shaft, have yet to have one come loose or spin.
    Stock props are marginal at best, would be better with some aluminum or copper ones in same size if I could find them.
    Props are 30mm 1.4 anyone got a couple:)
    Jun 2014
    1,516
    So it's something similar to this (not the right size, just for conversation)
    http://www.offshoreelectrics.com/pro...?prod=ose-1340
    I know I tore up the tip of the cable on my son's Shockwave with the straight coupler going from 2s to 3s with a 3000kv motor. Switched to the collet style after that and haven't had any issues. Do you think there is room in the assebly to use a collet?
    something like this (not the right size, just for conversation)
    http://www.offshoreelectrics.com/pro...prod=ose-81513
    Jun 2014
    1,516
    Maybe this is the answer for the 4mm prop shaft? would allow you to run 3/16" bore props:
    http://www.offshoreelectrics.com/pro...?prod=ose-1030
    Jun 2014
    1,516
    Jun 2015
    Tx
    87
    Going from the 4mm to 3/16 shaft is no biggy but finding 30mm 1.4 props has been the challenge.
    Jun 2014
    1,516
    6,191
    Part of me doesn't want to see it run. I don't want to shatter the vision of it running in my head.
    Noisy person
    Jun 2015
    Tx
    87
    Well it's going to be for sale so you can run it or shelf it if you buy it:))
