Results 1 to 5 of 5
Thread: Seaking V3 fast flashing red LED/fast beeping
Hybrid View
    Jun 2010
    CA
    147
    Default Seaking V3 fast flashing red LED/fast beeping
    I have Spektrum MR3000, SR301 receivers that work fine with other Seaking V2 ESCs... I purchased a Seaking V3 ESC and, on power up, the ESC goes into a fast flashing red LED/fast beep mode. What does this indicate, how do I fix?
    Pete
    Motley Crew, Impulse 31, Zonda Cat, Genesis, Aqua Rider tug, E-Revo Brushless, Slash4x4
    Apr 2015
    TX
    199
    Could mean it is detecting something other than zero throttle at power up. Have you already tried setting the throttle range calibration? Good luck!
    Jun 2010
    CA
    147
    ??? With all TX settings at default values, with the V3 ESC connected to the RX throttle connector, I bind the receiver.
    To configure the ESC with the program card, I've ordered a servo, female-female connector, hoping that will help.
    Otherwise, I'm at a loss with the V3 ESC.
    Pete
    Apr 2015
    TX
    199
    Binding the receiver is a separate process from setting the throttle range. Try this if you have not already-
    1. Power on the transmitter but have power off on esc and receiver. Hold full throttle on the transmitter and then turn on the esc. After a short time you should hear two beeps.
    2. Then release to neutral. After a couple seconds you should hear a long beep. That's it.
    Basically this just programs the esc to know what the neutral and full throttle signals are as they come from the receiver. Again if you have not done this yet it is worth a shot.
    Jun 2010
    CA
    147
    That worked! Thank you.
    Pete
