Results 1 to 9 of 9
Thread: Dumas Hawk FE
    Sep 2013
    331
    Default Dumas Hawk FE
    Maiden voyage dinogy 5000mah 14.8 42mm Graupner K series prop
    https://youtu.be/ZUfHhsvkFAI
    Keith Geusic #677 NAMBA District 19 Seaducer Gas MONO, Aquacraft Revolt Fe30, 30in Max Cat scratch Built
    Jun 2018
    vi
    4
    just wondering if you can help me out, have picked up a hawk partly built but no info or plans with it so i am trying to find out the distance from the rear to where the flex tube drops put of the hull. Cheers Dale.
    8,009
    Three-year-old thread, and the OP hasn’t been on the site for over two years. Don’t expect him to reply....
    Jun 2018
    vi
    4
    Ok thanks, just trying to get some info on the hawk.
    Apr 2017
    QL
    1,038
    let me know all the info you need about setting up the Hawk as my mate has one so i can get measurements from him.
    Jun 2018
    vi
    4
    Only rely need to no the distance from the transom to where the flex tube drops out of the bottom of the hull, cheers.
    Apr 2017
    QL
    1,038
    the Hawk has an S bent shaft log so it is best if you fit the motor first and then cut out the shaft log slot to suit. remember the Hawk was designed for glow power not electric so your going to have to re position where the motor is to be . you can either mount the motor as close to the rear sponson boom as you can and adjust esc and battery pack to suit c.o.g. or mount the motor in the radio bay compartment section close to bulkhead and position esc and battery up front. Look at the zippkits jae 21/fe build threads and take note where the motor is mounted, not sure if theres enough space to fit the battery pack / s between the sponson booms on the Hawk. the idea is to get the correct c.o.g. and then the Hawk will go well.
    Jun 2018
    vi
    4
    Cheers, that is a great . It will be a slow build so i get it set up just right.
    Apr 2017
    QL
    1,038
    If you can find any info on the Hawk 3.5 that designer Gary Pruess [ not sure on spelling ] did some years ago, this will also be handy for you as he did some upgrade mods that makes this rigger handle even better. lets us know how you progress.
