Results 1 to 14 of 14
Thread: Prop nut replacement?
    Nov 2013
    ok
    211
    Default Prop nut replacement?
    Do you guys know what size the prop nut is? Thanks
    Jul 2012
    mi
    774
    On what boat?
    Nov 2013
    ok
    211
    The voracity
    Jul 2012
    mi
    774
    Not sure have not lost mine yet. Same as my bj29, thinking if you don't want to order from hh take flex to a nut and bolt specialist and match it up hardware won't have one in stainless steel. All after market with .187 shafts are 10/32.nuts
    May 2015
    AR
    322
    I've got mine off and ready to go to the hardware store to figure it out. I'll let you know if no one has answered by this weekend.
    9,401
    It's either 5mm or American 10-32.
    9,401
    P.S. if you use a nylon lock nut, you will chance losing whatever prop goes on there. I used one once and lost a Dasbota 455.... Expensive!
    May 2015
    AR
    322
    You mean you lost a prop while using a nylock nut (steel nut with a plastic locking insert)? My Voracity came with a regular split ring lock washer and a nyloc nut.
    9,401
    Yep. I'll never use a nylock prop again.
    Use aircraft type lock nuts like the ones sold for American standard 10-32 thread. They have been crushed a bit before hardening to make them slightly oval causing you to use much more force to install and remove. Never lost a prop with the standard lock nuts. They are used in aircraft where loose nuts kill people.
    I bought some from fastenal in Canada. They carry metric versions. I buy my 10-32 nuts on eBay. http://www.ebay.com/itm/50-MS21043-3...item2ed35a84e6
    I don't know what they give you stock on the boat soi, it may be fine. I was using standard nylon lock nuts and never again.
    All my Chinese flex cables that I bought a while back had 5mm threads on them. I cut them off and cut new threads, 10-32 since I hate metric flex shafts.
    Dec 2010
    3,119
    Ray you can thread that hardened stub end, how are you holding the shaft ?
    9,401
    In a vice with some medium paper, lots of pressure. It's a bear to do. I chamfer the end first and use cutting fluid. The OD is actually a bit too large for the die but, I'm merciless.
    May 2015
    AR
    322
    I took the stock nyloc nut and lock washer to Lowes and the nut fit on both the 10-32 and a metric size thread gauges. I'm not sure if that's because their thread gauges are worn or the threads are just very close. I feel like I failed in my mission. Sorry. On top of that, the only 10-32 nyloc nuts they had are much larger than the stock nut so they will stick out into the water flow much more. Anyway, I'm not happy with those so I'm still searching for different nuts. The nut that is on the prop is the larger size. You can see how much bigger it is than the prop hub.
    9,401
    To find the right size nut easier, try a normal but first. Whichever goes on easier is the right size.
    9,401
    It would be nice if Pedro could chime in or call proboat
