Hi all. I picked up from my dad an old 41" deep vee hull that we used to run together a couple of decades ago. It is set up for a nitro motor and has the extruded aluminum mount already in there between the existing 5" rails. After emailing with Steve, we thought a Leopard 4092 would be a good motor for sport use (running on 6s). I need to get a motor mount and saw the HRC for sale on OSE. It states it is for Neu motors with 25mm mounting hole spacings. I don't want to spend the money on a Neu motor so was wondering...
Do you think the Leopard 4092 would bolt to the HRC 5" rail mount (part # ham-101525)? The mounting holes are specified as 25mm apart which is what I believe the 4092 uses. Or would it better to get a mount with rails and simply epoxy/fiberglass that in between the existing rails?
Thanks,
Matt
