Originally Posted by
Deepvee
Okay thanks for the info guys. I like the performance and I got the boat dialed in now so it runs great at these speeds. I guess I will purchase a better ESC that will support this set up. Any recommendations?
Yes you need a New ESC
But if you run 6S on that motor you will burn up the new ESC also.
The only way to run that setup is two SAW passes max at full speed, bring it in and let cool for 20 to 60 minutes.
If you want to run that motor change to 4S or stay at 6S and get a new motor with about 1500KV.
Where in Ontario are you?
Larry
