There are Mini Hydro (<450mm) SAW classes here in the UK and in Germany that I know of, probably elsewhere in Europe too, I don't know of any mini classes in the states if you are there, there are mini classes for oval and triangle racing with Naviga all over Europe and Asia too.
I have tried a stock v935, and a cut down detounged v935 on mine and neither worked, but I have the stock fixed driveline so couldn't adjust anything to help, x4--, x6-- and p735 two bladers all worked fine though, I will probably try the ABC 1/8" three bladers when they become available.Originally Posted by Jim82
Tim Gifford, that is insane! The 2836 motor I have pushes mine along well enough.
Neu, Lehner and Plettenberg are all top notch high end motors with great efficiency, I wouldn't like to pick between the 3, Lehner do make it easy to see the efficiency at any load though with the software on their site. I would be surprised if you needed more motor though, is it getting hot? We have similar KVs, my motor is smaller and I am able to run 6 laps with a detongued X632 (which should be more load) with reasonable temps, have you tried more prop?Originally Posted by Jim82
For sure! Mid 50s seems like hauling arse to me, I already need to exercise throttle control in most weathers, are you only running that fast in flat calm or does your extra weight over mine tame it enough? By the way have you measured yours? If not, could you please. I am pretty sure that I built mine to the letter, but I had to cut the tips off my sponsons to get it into our <450mm (<17.72") classes, I think it was just over 18" despite them saying 17".Originally Posted by Jim82
