Results 1 to 3 of 3
Thread: Futaba steering servo choice
    Mar 2015
    39
    Default Futaba steering servo choice
    Hi all, I am on choosing a good Futaba servo for my S-BUS2 install in my new pursuit hull. I have narrowed it down to 2 choices but I am not sure which one is best for the boat and racing. My main goal is not loose control or have any kind of servo stall when turning at high speeds.
    BLS371SV S.Bus2 HV ProgrammableServo
    FUTM0151>> Tech Notes
    Volts Torque Speed
    4.8 176 oz-in (12.6 kg-cm) 0.16 sec/60°
    6.0 219 oz-in (15.8 kg-cm) 0.13 sec/60°
    6.6 239 oz-in (17.2 kg-cm) 0.12 sec/60°
    7.4 264 oz-in (19 kg-cm) 0.10 sec/60°
    Motor Modulation Programmable
    brushless digital S.Bus2
    Dimensions Weight
    1.57 x 0.79 x 1.45 in
    (40.0 x 20.0 x 36.8 mm) 2.22 oz (63.0 g)
    HV 2BB MG
    Applications *Preferred
    cars electric, gas*
    boats yacht*, elec/gas*
    BLS471SV S.Bus2 HV Programmable Servo
    FUTM0155>> Tech Notes
    Volts Torque Speed
    4.8 127 oz-in (8.5 kg-cm) 0.11 sec/60°
    6.0 158 oz-in (11.4 kg-cm) 0.09 sec/60°
    6.6 174 oz-in (12.5 kg-cm) 0.08 sec/60°
    7.4 192 oz-in (13.8 kg-cm) 0.07 sec/60°
    Dimensions Weight
    (40.0 x 20.0 x 36.8 mm) 2.01 oz (57.0 g)
    HV 2BB MG
    I am leaning toward BLS471SV because it has the speed, but the BLS371SV has more torque, what would be best on water during racing conditions?
    Thanks,
    Oct 2013
    la
    8,740
    Are you dead set on futaba?
    Mar 2015
    39
    I will be using the SBUS-2 for sensors and their servos seamed a logical choice minimize wiring. Are there issues with Futaba BLSxxxSV servos?
Tags for this Thread
