There's a
1615
1715
1815
1915
A 1914 worked well on my 34" mono with a 1500kv 1527. Ran close to 70 on (67-69) 6s. I would definitely stay away from the older design high pitch props, your asking for trouble. The 1915 would be a good choice after you make sure your temps are in check with the 1914. A m447 two blade also worked well on my mono but the abc was better. With your setup being fairly close to what I have, I'd try the 1914 first. I also recommend making sure you have at least 6.5mm bullets on the motor and battery connectors along with short wires and a decent cap bank. You do these things and you should be where you want to be (or faster lol). I personally like overkill so I recommend upgrading the Esc soon.
The 1815 is very close to an m645 amp wise pulling a few less than the m645 does. In my boat it (1815)pulled I think 16 amps less (than m645). My mono didn't like the 45mm props near as much as the 47-48mm props. Could just be the way my bit is set up tho. I have a 1914 and 1915 for my new build. I suspect the 1915 to be a touch faster than the 1914. I am going with a touch higher kv this time so it should be in the low 70's on 6s.
