Results 1 to 2 of 2
Thread: 300+ pro ESC is going OFF please help
    Aug 2015
    ma
    9
    Default 300+ pro ESC is going OFF please help
    Hi people,
    To run an old surfboard I have 14s lipo 51,8v 20ah with a lehner torqstar 7040 motor winding 6 = 288 rpm under load, with a MHZ jet drive 64mm and a Swordfish 300+ ESC.
    The problem is, that the ESC is going off at more than 50% throttle.
    It just goes off and restarts again with the beep beep sounds, then it will work again.
    It is taking about 75A and 55v.
    I tried LVC different settings, and also 7.2v LVC and 2.5v per cell
    I also replaced my UBEB for an old fashion 4x AA battery 6v to be sure the receiver gets enough power.
    I also tried to go from 14s to 12s
    I also tried to increase throttle really slow.
    Temp of ESC is only 45 and a peak of 58 degrees celcius.
    Voltage drop is also very little
    Motor and ESC have good water cooling.
    What I did not do yet, is adding a capacitor bank, I know it is suggested, but since I have such a big battery with 20AH and 25C-35C batteries I did not install this yet.
    Is it possible that it has something in common with my problem?
    What else can I do ?
    See attachments for data.
    Aug 2015
    ma
    9
    Here is a .jpg from my log file. It does not show all data in the curve.
    I also can not make a log from the esc going off because if the esc will go off than the log file is also not saved into the ESC
