Results 1 to 6 of 6
Thread: 3000kv Motor, AQ ESC, 36mm Ring, Octura X637 S/B, 2 Wall Chargers
    Jun 2014
    1,516
    Default 3000kv Motor, AQ ESC, 36mm Ring, Octura X637 S/B, 2 Wall Chargers
    For sale, split shipping with buyer:
    1) Hobbywing EZRUN 13T/3000KV Brushless Motor ($25)
    Specifications:
    kV: 3000
    Motor Diameter: 36.0mm
    Motor Length: 50mm
    Shaft Diameter: 3.17mm
    Shaft Length: 15mm
    Weight: 170g
    2) AQUM7005 Aquacraft 45 Amp ESC Watercooled version w/ 5.5 Bullets battery side, 4mm bullets motor side ($30)
    Length: 3.15 (80mm)
    Width: 1.5 (38mm)
    Height: 0.3125 (17mm)
    Weight: 3.8oz (109g)
    Wire Gauge: 14 gauge
    Max Output Power: 900 watts
    Motor Connectors: Three 4mm gold-plated bullet connectors
    Input Voltage: 12-14 NiMH NiCd cells 8-20V input w/o BEC
    Output Current: 45A continous maximum 60A surge maximum
    Thermal Cutoff: 230 F (110 C)
    Operating Frequency: 8.5KHz
    BEC: 5.2V/2A
    Timing Angle: 10
    3) 36mm Tail Ring - Brand New ($5)(SOLD)
    4) Octura X637 S/B 2 blade prop (Too small for my setup) ($25)
    5) DYNM4113 chargers with EC3 Connectors, 2A Wall charger for NIMH ($25 for Both)(SOLD)
    Thanks for looking!
    NEVER SATISFIED RACING
    Fine Design 32 V-Hull 4082+6s
    Jun 2014
    1,516
    Pic of chargers
    Jan 2013
    nc
    198
    Is the motor smooth can or finned?
    Jun 2014
    1,516
    It has fins
    Apr 2015
    VA
    479
    I take the tail ring.
    Jun 2014
    1,516
    Tail ring sold
