Results 1 to 10 of 10
Thread: geico 29 v3
    Jul 2011
    141
    Default geico 29 v3
    can someone let me know if the new geico 29 v3 bounces like old ones? is the blackjack v3 29 the same hull design?? need to know before buying?
    Jul 2013
    No
    239
    Blackjack and geico is the same boat.
    It do not have the bounce issue like the v2.
    V3 hull its mutch more stabile. Have run mutch on 6s and it have never blow over.
    You must adjust your cog and if you get your prop sharp and balanced it would run better, less bounce and better handling. V2 needs blueprinting but v3 have mutch flatter sponsons so you dont need to do that.
    Nov 2015
    2
    How can you tell if the boat is a V3? iIam thinking you cant tell by just looking at the box itself.
    Wa
    5,905
    You could buy a new one from proboat I bet there will be Christmas sales
    Sent from my SM-G900T using Tapatalk
    Billy Graham
    Dec 2013
    az
    1,228
    Look at insides.. No more wood
    Nov 2015
    Wi
    Square hatch opening .
    Nov 2016
    44
    I just purchased a new Miss Geico V3 and would like to know what prop should I run thinking of a x440/3 but heard I would have to reset the timing on the ESC also not sure about the water line going to the top of the motor first. motor is a Dynamite 2000kv and plan on running on 6s
    4,100
    Quote Originally Posted by Fixitguy1 View Post
    Thought my last reply was pretty spot on, seeing as I ran that exact same boat/setup all summer.
    Nov 2016
    44
    Measure Twice Cut once. It's hard to figure out who is giving the best advice
    Thanks I found one.
    Apr 2016
    6
    throw the 2000kv motor in the lake.put in a 1650 or a Castle with a water jacket and let it eat
