Page 2 of 2 FirstFirst 12
Results 31 to 52 of 52
Thread: Burnt up 180A v3 hobbywing ESC?
  1. #31
    ON
    9,402
    Quote Originally Posted by mihelone View Post
    I use a 2s 800 mah lipo, its just a receiver and a servo to power...its ok for a rc boat.
    I use 800mah 2S up to 1200mah 2S but, high C rating so they can be charged fairly fast and handle the demands of almost any servo.
    Zippy 1000mah 20C are nice or similar. Don't go super cheap on ebay with no name lipos. Steve sells some I think?
  2. #32
    Jun 2015
    Wi
    734
    Ok cool. So Im pretty sure this thing is fried. I got a capacitor and soldered it in. ESC powers up but the led blinks red/beeps every 2 seconds, and the motor jerks slightly when it blinks. Bummer lol
  3. #33
    Jun 2015
    Wi
    734
    Im looking on hobbyking and noticed the v3 180a has an extra cap bank on the wires with what looks like 5-6 caps
    and mine had 2 anyone know what this is? Thanks
    http://www.hobbyking.com/hobbyking/s...r_Cooling.html
  4. #34
    CA
    4,407
    Have you contacted Steven on OSE yet? He is really helpful with these matters.
    Government Moto:
  5. #35
    Jun 2015
    Wi
    734
    I have not contacted him, but I already ripped the caps off of the main unit so unfortunately I think Im SOL at this point lol.
  6. #36
    wi
    232
    Quote Originally Posted by Mxkid261 View Post
    Long story short my spartan ESC finally started giving me issues after a year, so a month ago I purchased a 180A v3 hobbywing from the OSE store. Then about 2 weeks ago I purchased a Rivercat hull from Travis and decided to use the ESC for that. Well I had to try it out Lol so Ive ran about 8 times with it in the spartan and possibly burnt it up today. Boat cut out after about 5 minutes, got it quick with my jetski and when I pulled the top off there was a very small amount of smoke. Capacitors look burnt or something. Motor timing was 3.75 degrees on stock castle motor. Am I out $120 or is there any warranty on these? Thanks
    Five minutes is an awful long time to run anything with a hotter set up. Have you ran this set up checking heat every minute so you know you can push this that far?
    I try and avoid paste eaters.
  7. #37
    Apr 2015
    TX
    199
    Wow you are right, good catch! It is strange HW would let Turnigy sell their esc with improvements for less money then they do. I think it is pretty clear to me at this point the hw version needs some help in the capacitor department.
  8. #38
    Apr 2015
    TX
    199
    A slow blinking Red is the low voltage cut-off (but no beep) according to the manual. Did you test with charged packs? Also blinking Red with beep can mean it is in throttle calibration mode. There is still hope!
  9. #39
    Jun 2015
    Wi
    734
    Yes I tested it with charged packs. I guess I try rebinding or something?? I ran it about 5 times before it did this and for around 8-10 minutes and temperatures were never really that hot.
  10. #40
    Jun 2015
    Wi
    734
    I would like to think that this ESC should be capable of running longer than 5 minutes but maybe Im wrong? I beat the living crap out of my spartan for over a year always on 6s and never had a hiccup up until a month ago so thats why I bought the hobbywing 180, and this was with 10-12 minute runs sometimes 3 sets of packs in a row. I find it hard to believe I wouldnt be able to do the same with a 180a esc but again maybe Im completely wrong.
  11. #41
    CA
    4,407
    Did you remove the older caps before you installed the new ones? Many times when caps blow, they effectively become shorts.
    Government Moto:
  12. #42
    Mar 2015
    CA
    1,262
    domwilson: Can caps ever blow or get screwed up in any way without changing form or getting leaky, etc? I ask because a leg on all 4 of my stock caps on my SF 200A 8s look like they have either burnt and shorted or bent to the point of ripping the legs in half... which I find hard to believe that I could mess them up that badly when repacking/retaping the ESC. Especially since it happened to all 4 of the caps. Though... I resoldered them back-- the ESC works fine and has an additional big cap bank. I noticed this sometime after a meltdown of 2 tp4050 motors... this ESC was the only one without an additional cap bank (the other ESC had the additional one) so I'm starting to think it might actually be a good idea to just replace them with new ones.
  13. #43
    Mar 2015
    CA
    1,262
    mxkid261: I have had a similar episode with a Seaking180 ... except the ESC literally blew up and the pressure ripped through the front of the carbon fiber hull blasting into my leg lol. But anyways... my point is that it seemed like it could have been caused by the motor shorting and overheating. These ESC don't seem as bulletproof as people make it seem to be. Perhaps check out your motor and your soldering on the plugs.
  14. #44
    Feb 2015
    8
    This is the link for the video with the osprey I am talking about with all the mods (replace caps, external bec).
    https://www.youtube.com/watch?v=N9Zam3OEoac
  15. #45
    Jun 2015
    Wi
    734
    Domwilson yes I removed all 4 old caps before soldering in 1 new one to bench test. Dmitry that must have been quite the pop LOL. I have a feeling the pos castle motor maybe took it out. I hooked up the vxl-6s and everything powered up as normal.
  16. #46
    CA
    4,407
    Quote Originally Posted by dmitry100 View Post
    Yes. Electrolytic caps can dry out over a period of time or heavy duty cycles. In addition, After you replace the caps with similar or higher values, I would still investigate why they blew in the first place. Perhaps check the drive train for any binding. Your strut adjustments, weak batteries, too long battery wires, etc. These all can contribute to this failure.
    Government Moto:
  17. #47
    Mar 2015
    CA
    1,262
    domwilson: Well, the main reason was that my shocker flipped and the throttle failsafe was not setup correctly since the throttles are set to reverse on that radio... so both of the motors were at full throttle (50k rpm) for like 5 minutes by the time I can get to it... and they melted along with the whole drive lines and tubes. Thankfully the ESC's were fine except for the cap legs on one of them which may or may not be related to the incident. The ESC's were brand new and had no other use before that though.
    So better safe than sorry and just replace them then?
  18. #48
    CA
    4,407
    Yes. Even with a cap tester, I still would.
    Government Moto:
  19. #49
    Apr 2015
    TX
    199
    Hi domwilson, same sea king 180. I thought I had it under control but I noticed my caps get hot at times. Not sure if it driving style or what. Batteries, esc, and motor seem fairly cool but the caps are noticeably hotter. Will not having enough capacitor cause this and would it be beneficial to replace the 2 390uf caps with 1000s? How many would you use and not be overkill? (32" mono, 4092 1480kv 5s & 6s)
  20. #50
    CA
    4,407
    Yes you could try the larger caps. But I would look at why the caps are working so hard. Do you have a different, higher capacity, batteries you can try?
    Refresh my memory, What batteries are you using? What size connectors on the battery and motor ends? Can you take a pic of the insides of the boat?
    Government Moto:
  21. #51
    Oct 2011
    OZ
    314
    Ok. I've got popped caps on my v3 as well. System was running fine with no real heat anywhere and a pretty conservative setup. Just so I'm clear. I can remove the 2 popped caps on the body of the esc and seal off the holes. Then remove the caps on the leads and install a new cap bank, and this *may* fix the esc? Then stop using the internal bec also.
    Are the 220 amp swordfish esc's any comparison to the 180v3?
    PERTH AUSTRALIA
  22. #52
    Apr 2015
    TX
    199
    Iron-paww, I am not sure anyone has been successful yet removing the on board in the v3. I guess unless you are going to pursue warranty you don't have much to lose trying it. The op did remove his but it sounds like his esc is still doa.
    Domwilson, for batteries I use series 2s and 3s 7200mah 60c from SMC with ose 6mm bullets. I only use 3000mah to 3400mah after about 4 minutes. On paper I should be okay I think. I have just installed an external BEC with a 1000mah 2s. Curious to see if that helps any. I'll try to get a picture posted.
