Page 2 of 2 FirstFirst 12
Results 31 to 45 of 45
Thread: New abc props
  1. #31
    Mar 2015
    1,262
    Meniscus: Have you tried anything like the Ceramic grease like the kind MBP has?
  2. #32
    Jul 2008
    VA
    3,225
    Without hijacking this thread, I have tried many, many different types of grease and many types of oil for bearings. This includes blends as well.
  3. #33
    Mar 2015
    1,262
    Meniscus: Any noticeable speed increases when using Nano oil over things like blue grease in the drivelines? Kfxguy mentioned using duralube before but I'm not sure how he uses it or if he blends it with grease to thicken it a bit....
  4. #34
    Oct 2013
    la
    8,740
    Quote Originally Posted by dmitry100 View Post
    I don't remember ever saying I use duralube. I use motor oil and graphite powder or proboat grease.
  5. #35
    Mar 2015
    1,262
    kfxguy: Oh ok, my bad then. It might of been Srislash that made mention of it.
  6. #36
    Jul 2008
    VA
    3,225
    I cannot and will not make any claims with regards to speed increases when using Nano-Oil. However, I can say that everything feels more smooth and the grease in particular does not become sticky, unlike many others I have had the opportunity to run in the past.
    This being said, if you are seeking additional input, I would recommend starting a new thread specifically for this topic and garner comments from others concerning what they use. Meanwhile, it will allow this thread to return to the original topic.
  7. #37
    7,631
    Guilty I use Dura lube and Lucas Marine Greece
  8. #38
    Oct 2008
    9,488
    is this better than just using grease ?
  9. #39
    7,631
    It totally freed things up Todd. Grease like normal then a couple drops of the oil in the top of the flex.
  10. #40
    Mar 2015
    1,262
    srislash: Would it be better to maybe just blend the 2 together 50/50 ? Thats what I've been doing lately and it seems to have a noticeable difference... or I could just be seeing things.
  11. #41
    7,631
    Which ever works Dmitry. I will tell you that I forgot to add the oil awhile back and my speed went down to 92 from 101 with the mixture.
  12. #42
    Oct 2013
    la
    8,740
    So you lost 9mph from not adding oil to the grease?
  13. #43
    7,631
    Yup
  14. #44
    Mar 2015
    1,262
    srislash: Oh wow, thats pretty significant difference then. How often should I be regreasing the entire driveline? Seems like alot of work to do it after every run. Perhaps I should just add some oil from the grease fitting of the STS tube seal instead of regreasing it all every time.
  15. #45
    7,631
    The gas guys claim that perhaps a thicker gear oil can be used in that exact way. I usually re-grease after my day out but since my 'clicks' and bearings I don't pull it apart to often. BUT, it did take a bit to seal the assembly to that point where water does not contaminate the oil/grease mixture. Until that point daily greasing should be done. Bear in mind I am only referring to my Fantasm, all my other boats still get the end of day cleaning/degreasing.
