Page 4 of 4 FirstFirst ... 234
Results 91 to 103 of 103
Thread: DF pirate 35" first build
  1. #91
    Jan 2013
    ca
    84
    Yeeoowwww!!! 100%
    Set in tub for 30 min, no leaks! All that's left is some soldering connectors for the charger! Damn I'm pumped! More than likely maiden voyage this weekend, I'll def post video, even if it's all bad ( better not be) lol. Ready to rip! Paint is next, nothing as spectacular as dana's I'm sure but I'll do my best! Thanks guys!
  2. #92
    Jan 2013
    ca
    84
    What is recommended for max voltage you should charge 6s lipo's?
  3. #93
    Jun 2013
    VA
    91
    6amps balanced
  4. #94
    Mar 2008
    Au
    806
    4.2 volts per cell x 6
    Brisbane,QLD, Aussie
  5. #95
    Jan 2013
    ca
    84
    Thank you guys. Thought so, 25.2 per 6s pack
  6. #96
    Jan 2013
    ca
    84
    Well I'm happy to say the maiden voyage went... Well pretty well. It ran super wet, have some setup adjustments to make, it was really windy out so not a bad thing. But it was pushing they the water pretty heavy. Stinger setup should be at what angle? Have a little link to mono trim tabs and stinger angles? I didn't get video, but I'll video next outting for sure. Overall ran really good, but I don't know what you call it but at full throttle the hull really twisted/leaned from the torque.
  7. #97
    Jan 2013
    ca
    84
    Sorry boat hasn't touched water again yet. Work is crazy. Might et a chance to get a run in this weekend with some video. Keep yuh posted.
  8. #98
    Jan 2013
    ca
    84
    https://youtu.be/e1Mm7BUoVGM
    Finally got some video. Thanks to the wife.
  9. #99
    Feb 2016
    RS
    15
    Hi. How do you know where to make the holes to install the hardware ? How do you seal the hole ?
  10. #100
    7,630
    Quote Originally Posted by wolffman View Post
    Wolffman, determining the height of the hole from the keel has to do with the prop size you intend to run. That being said, a hole Center of 3/8” from keel would be good for this hull. A little higher for more stable running and lower for speed but less stability. This hull likes a 47-50mm prop
  11. #101
    Feb 2016
    RS
    15
    Nice! I want the boat as fast as possible. What about the trim tabs an the other tubes ?
    Thank you
  12. #102
    7,630
    You want the bottom of the rudder blade about 1.5” below the prop and the trim tabs you set them up about 1/16” above the hull edge.
  13. #103
    Feb 2016
    RS
    15
    Thank you
