Well I went and order myself a Hydro & Marine Lobster boat on May 30 and after checking the tracking info today, I am very excited as it has arrived in Aus and is on it's way to the local dispatch facility should have it by the weeks end if not sooner
This hull is a custom build using a combination of light weight fiberglass and Kevlar and according to Oliver came in under 1000 grams, not bad I guess for a 31" hull.
I'm planning to run this in 2 of our 4s classes, 1st being restricted rigger, 45amp ESC + Proboat 1500 motor, hence the reason for light weight glass. Hoping it's not going to be to heavy for this setup and is competitive against the other racers.
2nd class is open rigger, so any motor and ESC on 4s. Not sure what I'll use yet! I have a Feigao 8xl on the self i may use till i decide on a more permanent motor.
Will post pics when it arrives
