Results 1 to 11 of 11
Thread: Lipo use as power supply? Anyone attempted?
    Apr 2015
    VA
    479
    Default Lipo use as power supply? Anyone attempted?
    I am looking for a lighter weight option for lake side charging other than hauling a deep cycle marine battery around.
    Has anyone ever used a few 3s lipos(12v) or 6s (24v) to power thier charger?
    Aug 2012
    ma
    1,361
    Watt hours are watt hours. You would only be able to charge the equivalent of the packs supplying the charge, minus some efficiency loss in the charger, not sure why you would do that, just run the extra set of packs.
    I guess you could charge (3) 2s packs if you powered the charger with a 6s of the same mah rating, but that's a lot of hassle.
    Sent from my SM-G920V using Tapatalk
    Apr 2015
    VA
    479
    Thanks Kevin. Thats what I was afraid of. I have about a 10 Min walk from car to shore and I'm Looking to reduce the load that I have to carry.
    Aug 2012
    ma
    1,361
    Quote Originally Posted by shua View Post
    Sounds like you need to build yourself a wagon of some sort.
    Apr 2015
    VA
    479
    Quote Originally Posted by kevinpratt823 View Post
    read my mind Sir!! I have an old busted two wheel cart and I'm planning to build up some mobil charging/tool cart from that!! Or I saw a rolling tool chest at Northern tool the other day that may fit the bill as well! I have found a deal on some "aged" (new old stock) pair of deep cycle marine batteries to supply the 24v. Its a start!
    Apr 2015
    VA
    479
    And so the Mobil charging station build begins.....
    Oct 2013
    la
    8,740
    That's going to be pretty awesome!
    Apr 2015
    VA
    479
    Thanks! I will post up a build thread on it.
    US
    5,557
    Very nice!! Trays for driveware and props, and lipos underneath the trays.
    May 2014
    ny
    139
    Yes I need one of these also, nice setup.
    Apr 2015
    VA
    479
    In my build I'm thinking of adding some 5v usb ports for charging/using Phones, mobil devices, etc AND some sort of intergrated sound system for streaming music lake side! YEAH!
