Results 1 to 5 of 5
Thread: genesis motor upgrade help.
    May 2015
    oh
    19
    Default genesis motor upgrade help.
    I am looking to upgrade the stock sss 3674 2075 kv 6 pole motor in my genesis. I have installed a new hobbywing seeking 180 esc last month , and would like to run 5 and 6s lipos.
    the prop is a 3 blade cnc 42mm. i was looking at the TP power 4050 1700kv motor or the Leopard 4082 1800kv Motor.would like to here what you guys think is the better motor for my setup.
    May 2015
    Mo
    10
    No one's ?
    I want to know also ...im thinking of the same upgrade 4074 --- 4082
    Im mostly running on 4s.but like to try 6s laiter May be
    Advise plz:
    May 2015
    oh
    19
    i got the Leopard 4082 1800kv Motor, and it runs great. i would still like to know which motors are better, tp or Leopard
    May 2015
    oh
    19
    This is the current setup with the leopard 4082 motor.
    Apr 2015
    KI
    13
    Leopard 1600kv 4082 running on 5s. 80km/h with Octura x447. Average draw is 50-70Amp, 150Amp peak.
    Btw, i would strongly advise to replace battery pads. After last fly my 5000mAh 5s packs ripped both pads off.
    These pads glued to small plywood stands. Glue is low quality; I removed what’s left of it from the hull pretty easily. And part of pads simply exfoliates.
