Results 1 to 10 of 10
Thread: Hobbyease Cats.
    Nov 2008
    Ql
    3,169
    Default Hobbyease Cats.
    A couple of cheap Hobbyease cats outrunning three Cheetahs at our club. Excuse my sloppy driving where I cut a couple of buoys.
    May 2013
    Sg
    44
    Nice run!
    Do u have picture of which cat from hobby easy?
    Nov 2008
    Ql
    3,169
    Yes. it was this one.
    http://www.hobbyease.com/super-yacht...lue-p6042.html
    But there is a lot of things to do to it for it to be able to run like that.Have a read of this & you will see.
    http://www.rcgroups.com/forums/showthread.php?t=2196298
    Cheers.
    May 2013
    Sg
    44
    Wooo! Spider! U the man!!! it won the race!
    Good job !
    9,402
    What is the actual length of the boat in inches? Sometimes they give you the length including hardware.
    Nov 2008
    Ql
    3,169
    Ray.
    From tip to transom is 31-1/2" & 14" wide.
    But I've just had this one delivered for our Offshore Cat class. It's 41" x 16-3/4"wide.
    Here it is next to the little one.
    May 2013
    Sg
    44
    Wow! Another one !! Gasoline power? Btw care to share what did u do bottom of the hull ?
    It handling so well on your hand!
    Nov 2008
    Ql
    3,169
    Yiming.
    The big one will be electric with a Castle 2028 Motor on 10s
    The only thing I did to the bottom of the hull was to lightly scuff all the shine off the gelcoat with some #400 grit paper. Same as I do to all my hulls. That just reduces a bit of drag.
    9,402
    Quote Originally Posted by 785boats View Post
    Ray.
    I think I had one of those or similar and traded it for a Cheetah with Tom C. In MI.
    May 2013
    Sg
    44
    Yiming.
    785
    Ok Tks for the ideal!
