Results 1 to 4 of 4
Thread: x642 or M545
    May 2015
    100
    Default x642 or M545
    I just ordered a leopard 4074 2200kv with the 180amp esc. I plan to run this all on 4s with 6mm bullet connectors on everything. I want to get around 50 with good run times (3-5 minutes), while keeping everything at a safe temperature. Which prop would be best for performance and temps? Feel free to suggest any props for this setup!
    May 2012
    940
    I made my water pickup go out the bottom of the rudder. Best thing I to improve the Revolts cooling. Tracked with Eagle Tree so I know it worked. Good luck.
    Do It Like You Mean It .....or Don't Bother
    US
    5,557
    They will be very similar................... both good choices for 4s.
    May 2015
    100
    I'm going to start with the x642 and if temps are good, then I will move up to the m545
