I have both the HK Genesis and Outerlimits boats. The factory "glue" used to adhere motor/ESC/servo mount to the hull will fail as it is some kind of "hot gun glue". When I received the Genesis, the motor was flopping about the hull, held in place by the flex shaft.
I removed the motor mount, cleaned off the factory glue, laid down a re-enforcing layer of fiberglass (or CF), followed by the motor mount.
In the Genesis, battery, ESC connectors are EC5 and wired in parallel.
Pete
Motley Crew, Impulse 31, Zonda Cat, Genesis, Aqua Rider tug, E-Revo Brushless, Slash4x4
