Page 2 of 2 FirstFirst 12
Results 31 to 32 of 32
Thread: Project Fast cat maiden run
  1. #31
    Oct 2013
    la
    8,740
    Quote Originally Posted by Turbo Dan-O View Post
    Nice runs! Dang, that thing is nasty fast!
    Thanks! Charging batteries right now. Got a new prop to try so I'll try and make some runs today.
  2. #32
    Oct 2013
    la
    8,740
    Project fast cat is now at 82.3mph on 5s and 96.0 on 6s. Got some more tweaking to do. I'm pulling a max of 173 amps on 5s so I may be able to go up a touch on the prop. Think it was in the low 200's on 6s. I need to bring my laptop next time. I do have a few more props on the way. I tried 7s again but it would not stay on the water. I don't count speed runs when the boat flys off the water. It did go 97.3 before lifting. This is how I'm thinking it works, I could be wrong. The gps can only read when the boat is flat on the water, when it lifts, the hull is carbon do it blocks the signal. So my thought is the speed records is when the boat was flat on the water. My whol point is not that the boat went 97....but it was going 97 and crashed and came out once again unhurt. Here's the flip...
