Page 1 of 2 12 LastLast
Results 1 to 30 of 48
Thread: My first attemp at 5s with my stock HK Pursuit:)
    Aug 2014
    qc
    390
    Default My first attemp at 5s with my stock HK Pursuit:)
    Hi everyone, Here is my boat on 5s for the first time, and the first run of the season for me!
    Please leave comments if you think i need to correct something.
    https://youtu.be/xli-PYuL2X0
    Thank you and enjoy!
    Apr 2011
    5,666
    Looks good!
    Feb 2011
    TN
    292
    Heck yeah! Been wanting to put my stock Pursuit on 5s. Is yours still stock motor and prop?
    Pursuit: T-180, TP 4060/1620kv. Genesis: T-180, GoolRC 2000kv. UL-1: Bone stock. MHZ Tsunami: Full tilt SAW project!
    Aug 2014
    qc
    390
    Quote Originally Posted by Turbo Dan-O View Post
    Yes, everything is stock, exept for the esc.
    Aug 2014
    qc
    390
    Hi, here is today's run! I think i'm getting somewhere! https://youtu.be/81y4eRw-WK4
    Feb 2011
    TN
    292
    Nice! Any changes? I just put an M445 prop on mine and it really woke it up! I'm still on 4s...
    Aug 2014
    qc
    390
    Yes, a few changes!
    1-i sharpened the stock prop.
    2-i moved the COG to 9''3/8 from transom.
    3- i place the batts right behind the motor.
    and 4- i added foam for more flotation.
    i tried the Grimracer 42x55 and got to 61 km/h. With the octure x442, got 58 km/h. i didn't use the gps for the last run, but it looks faster with the sharpened stock prop.
    You should try 5s with that boat, it a great adrenalin rush!
    Feb 2011
    TN
    292
    How is it going Boilo? Any updates yet?
    Aug 2014
    qc
    390
    Well, i received my props!!! And a tested the x443 on 4s, it was a bit slow, around 42kph. Then the x442/3 4s i got 51kph. And after this a ran the x440/3 on 5s for my last run of the day, and a got my NEW SPEED RECORD, 67kph. But on the last run i had to move the batts about 2'' forward, in order to keep it on the water, and even then, it was still a bit too dry. I cant wait to see what it will be with my new esc and motor! I will post the vid here in the video section in a few minutes!
    Aug 2014
    qc
    390
    Here is the complete run not edited. You can skip from 4:50 to 5:40, it is only my cam looking at the grass. https://youtu.be/HLZRM0FBfdA
    Aug 2014
    qc
    390
    Finally, my parts are arrived !!! Look at these beauties!IMG_20150612_175829.jpg I'll test the setup tomorrow, and see what kind of upgrade this will be!
    Feb 2011
    TN
    292
    Nice! Why the new ESC? And what are the motor specs?
    Aug 2014
    qc
    390
    Hi, The motor is a 4 pole inrunner, 2200kv, winging 2.5d continuous current 70amp, peak current 100amp max power 1200w. This is what is written on the box.
    I'm waiting on my batteries to finish charging to go try this setup!
    Aug 2014
    qc
    390
    The new ESC is 'cause the MM2 need to go back in my Slash 4x4!
    Aug 2014
    qc
    390
    But i tought it would be a good idea to install the traxxas telemetry on it, for voltage and temps!IMG_20150613_115619.jpg
    Feb 2011
    TN
    292
    Oh cool! I would love to do something like that. I always thought that had to be "built in" to the ESC.
    Edit: Just did a search for it. That is wicked cool! Be sure and post up your results!
    Aug 2014
    qc
    390
    Just got back, I tried the X440/3 and the X443. It was too windy to go WOT, but on the X440/3 i got 70kph at 2/3 throttle. i didn't movitor the speed for the X443, but it looks crazy fast!https://youtu.be/s089W3KTqoEIMG_20150613_133425.jpg
    Aug 2014
    qc
    390
    I have some problems with my new ESC. The led starts blinking after a few minutes of use. The batteries were full. See what i meanhttps://youtu.be/zb6Ifl_HHQU Please some help would be very appreciated!
    Aug 2014
    qc
    390
    Quote Originally Posted by boilo56 View Post
    Forget this, i solved it. It was LVC kicking in early.
    Aug 2014
    qc
    390
    Hi went running the boat again, everything was fine! Here is the first complete run:
    Aug 2014
    qc
    390
    Here is the second run:
    Aug 2014
    qc
    390
    Here is the third run:
    Aug 2014
    qc
    390
    And here is my last run of the day:
    I wasn't able to go WOT on the first pass.
    Aug 2010
    uk
    2,887
    With the front of the boat coming up like it is it looks like you have to much positive angle on the stinger ( angled up to much prop end ) or the centre of gravity is to far back.
    Aug 2014
    qc
    390
    Good thing to know, i was thinking of lowering the trimtabs a bit, but adjusting the stigner angle seem easier. Thank you for your input!
    Aug 2014
    qc
    390
    But it was so cool to see it riding only on the prop like that!!! I will try it again some time!6-14-2015_003.jpg
    Aug 2014
    qc
    390
    Also, the COG is around 9''1/2 from transom. Batts were far in front.
    Aug 2010
    uk
    2,887
    Cg needs to be around 9.75" in from transom as a starting point, re stinger & tabs angle start with them neutral ( parallel with the hull bottom ) & then adjust as needed.
    Aug 2014
    qc
    390
    The trim tabs are at ''0''. Stigner is around 1 to 1.5 degrees positive from factory. Maybe if i move the ESC right behind the motor. Would it help the COG?
    Aug 2010
    uk
    2,887
    Your cg is not far out, moving the esc back would help but I would take a bit out of the stinger angle & run again.
