Hi guys,
I just bought a Swordfish Pro+ 200A 8s. To my surprise its not exactly completely waterproof, but just "water resistant"... figured it would be for the money being a marine ESC and all. Probably would cost the manufacturer next to nothing to do it properly at the factory... I don't get it.
So, What would be the *best* way possible to waterproof this thing completely?
I read a tutorial about using "3M Scotch-Weld Epoxy Potting Compound DP270 Clear" to do it. >> http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
But I want to make sure this thing is 100% bulletproof when it comes to water-- No build up of moisture, no nothing... even if it ends up underwater for an hour :)
This is what I have on hand:
Will the Plasti Dip and Silicon be suitable for this? Or should I just go ahead and buy/use that 3M Epoxy Plotting compound... and then wrap it up with the waterproof fuse tape. Since I don't have a heat gun... I was thinking to put the original wrap back on somehow since I want the SF sticker intact. How should I put it back together without needing a new heat shrink for it?
Also, is this the newest Swordfish version of the 200A 8S? Just want to make theres no V2's of this around.
Thanks!
Dmitry.
