Results 1 to 8 of 8
Thread: ose strut question
    Apr 2015
    40
    Default ose strut question
    What kind of grease is best used for the ose upgrade strut system?
    Mar 2008
    Au
    806
    Any marine type grease or thin oil like 3 in 1.
    Brisbane,QLD, Aussie
    Apr 2015
    40
    Do you need to grease the wire or can u just use the grease fitting on the strut?
    Mar 2008
    Au
    806
    Grease the whole cable except for the tip where it fits into the motor collet.
    Apr 2015
    40
    so just can't use the fitting on the strut? Was wondering why they had a fitting if you still had to take it out and grease the whole cable.
    Mar 2008
    Au
    806
    I know not of the strut you talk about but i guess it is for top up lube during the day.
    Apr 2011
    5,666
    Is this the strut you are talking about? http://www.offshoreelectrics.com/pro...rod=ose-C-1405
    As said, you can pump grease in between runs, but at the end of the day, normal procedure takes over and you need to take out the cable and re grease.
    Apr 2015
    40
    Yes that is the strut. Thx for the info.
