Results 1 to 11 of 11
Thread: swordfish 240 esc help
    Dec 2014
    Me
    101
    Default swordfish 240 esc help
    Just recently put power to this esc and hooked up my program box to it. The screen "update your esc or press ok" when I press ok the screen goes blank??? Would appreciate any input thanks.
    Good times had by all!
    May 2009
    AB
    483
    Do you have both leads from the esc plugged into the box like Diagram 2 opto esc in the instructions?
    Switch on?
    Brian
    Namba District 16
    1/8 Miss U.S., 1/8 59 Maverick, 1/8 Executone, 1/8 Smokin Joe, 1/8 Bud, MLGSX380, AC Pro40II Q Sport, AC Pro40II nitro,Twincraft mono 10s, Vision AOPC, VS1 FE, M34.
    Dec 2014
    Me
    101
    Yes, the receiver lead and the lead that consists of a black and red wire. Bolth have been plugged in and it won't get past the first screen after o press ok it just goes blank... maybe its a program box problem??
    Thanks for your response
    May 2009
    AB
    483
    Did you try checking the box firmware thru the pc link? A long shot mine was up to date.
    Brian
    Namba District 16
    Dec 2014
    Me
    101
    Maybe that's the problem.. I'll have to get the USB link and try it.
    Aug 2013
    Fl
    2,451
    It's probably a firmware update problem, have you had this ESC a while and just now using it?
    Dec 2014
    Me
    101
    Just got it a couple weeks ago.
    Aug 2013
    Fl
    2,451
    Dec 2014
    Me
    101
    I did not but I haven't done anything out of the normal with this setup. I will go over all options.
    Aug 2013
    Fl
    2,451
    Go through those instructions and see if you missed something.
    May 2008
    OH
    774
    The controller HAS to be connected to the computer to update software, other wise where is it going to get the update from?
