Page 3 of 3 FirstFirst 123
Results 61 to 69 of 69
Thread: New TP motor only a few runs shaft spun out?
  1. #61
    May 2014
    le
    58
    had same problem with a tp motor in a mcd v4, spun its shaft in the rotar, don't know if grub screws had sheared but there wasn't much of a flat spot on either end of shaft, tp replacing foc, they told me they now use a different glue so problem shouldn't happen again, to be fair to tp they were very good with their after sales service, so good ive ordered another tp motor off them
  2. #62
    Apr 2011
    5,666
    Quote Originally Posted by bayareaheli View Post
    I will forsure, here is my motionless cheetah for now lol
    Wow, very nice looking boat, the tug is nice too.
  3. #63
    Jul 2014
    144
    Thanks tlandauer!
  4. #64
    Jul 2014
    144
    Got my TP motor back and installed.
    I have a question about my TP motor Timing
    here are the Parameters:
    T: 3Y
    KV: 1720
    Max Amps (A): 213
    Max Volt (V): 29
    Continuous Power (W): 3050
    Max Power (W): 6200
    Max RPM: 50 K
    Rm (Ohm): 0.0095
    No-load Current (A): 3.8
    Shaft Diameter (mm): 5
    Diameter X Length (mm): 39.5 X 90
    Weight: 455 g
    Pole: 4-pole
    What would be the optimal timing for this motor
    My Leopard 180a esc timing offers:
    1 - 0.00
    2 - 3.75
    3 - 7.50
    4 - 11.25
    5 - 15.00 (default timing)
    6 - 18.75
    7 - 22.50
    8 - 26.25
    I have been running default timing.
  5. #65
    Aug 2010
    uk
    2,887
    Your motor being a y wind 10-15 degrees, the default setting will be ok.
  6. #66
    Jul 2014
    144
    Thanks for the reply Martin will leave it default setting then.
  7. #67
    Jan 2015
    ca
    25
    What prop are you using on that 4060? It is a 1720kv correct?
  8. #68
    Jan 2015
    ca
    25
    I have the same motor in Mean Machine and want to get the correct prop
  9. #69
    Jul 2008
    VA
    3,225
    Recommend removing shipping information on previous posts for obvious reasons. No reason to advertise.
    Please also check your strut. If you find that there is excessive heat there, it could be binding. It may not be apparent by spinning the driveline by hand or testing on the bench, but once under load in the water, it could be generating too much heat. I always try to check at the conclusion of each run. I've only found the issue on one run out of the past 300 or so. It may be rare on my setups, but it is always good to check things to avoid other issues down the line.
    Another thing that hasn't been mentioned is whether or not the motor ran hot previously. The extra heat previously could have compromised the motor and the failure wasn't triggered until a possible quick deceleration or similar such as a crash.
    Just a few things to think about for the future, regardless of what motor you employ.
