Results 1 to 4 of 4
Thread: X645 for a modded BJ29 v2?
    Jul 2013
    Mi
    200
    Default X645 for a modded BJ29 v2?
    Im running a modded BJ29 v2 with a 1400 kv Leopard 3674 motor and a SK180 v2 esc. This is a dedicated 6s setup that ran awesome with a prepped X642. Temps came back under 130 after timed 3 minute runs unless the water was in the 80's.
    My X642 got trashed after hitting a piece of rope that was floating in my course area.
    Given my setup, is it possible run the larger X645 without issue?
    US
    5,557
    I think you are already at a great prop with the x642, plus your temps are close to being at what I consider the high end(135* to me is tops) The boat should be plenty fast with the 642
    Oct 2013
    la
    8,740
    I find the x or m 645 makes a smaller hull like that unstable when swapping from a 642. I did this comparison by accident last weekend and the boat flipped easily. I think it had more lift so it will require retuning to adapt for it. I put the 642 back on and it was stable again. The boat does over 70 with the x642 so I know it's enough prop to go fast.
    Jul 2013
    Mi
    200
    Glad i asked. I will just order another X642 and call it good.
