This is a BK Bandit S. It is 29" long and 9.5" wide. Weighs about 1.4lbs. It has a double pick up flush mounted in the sponson and a dual out put on the side. It has a rudder and rudder bracket already installed along with motor mount, a screw off type antenna, power switch, and stuffing tube guide is cut. The rear was deeped to allow a larger prop selection and more power. All glass and motor mount is glassed in and rear cut portion is glass.
http://www.bk-electronics.com/catalo...oducts_id=1556
Rudder and strut not shown....oops
Also available is th e"power package".
6 pole 1350Kv motor. Hextronix Quannum. Cheap but it has power enough for good sport running. ESC is water proof/water cooled 70amp TowerPro.
