Results 31 to 60 of 83
Thread: Water cooled mamba xl2
  1. #31
    9,402
    Quote Originally Posted by kendt View Post
    http://www.hobbyking.com/hobbyking/s...o_Car_ESC.html
    They are a copy of the castle unit but much cheaper.
    If you go to SkyRc's web site they will show you the internals, very different from the Castle but, thats just my opinion. Good deal at HK.
  2. #32
    9,402
  3. #33
    Apr 2011
    5,666
    Interesting internal layout, still, I wouldn't have the ability to water cool it.
  4. #34
    Jul 2011
    on
    557
    Thats a totally different version. The version sold by hk has the same layout as the castle.
  5. #35
    Oct 2013
    la
    8,740
    Do you have a link so I can see how the internals are laid out? I'm not afraid to buy one and convert it.
  6. #36
    9,402
    Interesting, my bad.
  7. #37
    Jul 2011
    on
    557
    http://www.etotheipiplusone.net/?p=3096
    Here you go. Scroll down about 3/4 of the page. They are pretty much exact copy of the castle.
    You can see how the fets are closer to the middle and the heatsink actually touches the metal bars beside the fets. I will beusing thermal rubber to better pass heat from the fets. I wanted to use copper foil since I happen to have a ton of it but that would short out the esc.I put an ohm meter on the metal strips and they are connected with the motor wires.
  8. #38
    Jul 2011
    on
    557
    I took a look at mine. It looks like a leftover SF 200a wc plate is a great solution for the castles. I have some pics. When I get a chance to crop and load em I will show what I did.
  9. #39
    Oct 2013
    la
    8,740
    That board looks exactly like a hydra 240 and mamba xl2. I want to buy one now but I wonder what programming software it uses and if it data logs like the castle.
  10. #40
    Jul 2011
    on
    557
    Off the top of my head I dont think it does data logging.Its not a huge deal for me since the data logging on the castle units in general seem to have a reputation for being in accurate.There is a program card available for them. I wouldnt be at all shocked if the castle software works on them since its an obvious clone.
  11. #41
    9,402
    Cool, I have one of those here... Thanks
  12. #42
    Jul 2011
    on
    557
    I removed the little heatsink under the driver board. Moving the caps out of the way, the sf plate fits perfect.20150307_095930.jpg
    It looks as though .5mm thermal pad on either side and the two pieces will be a perfect fit. All that's left is to mill out some fines on the other half of the HS for brass tube. Providing of course I don't come up with something better.20150307_100139.jpg
  13. #43
    Jul 2011
    on
    557
    Ok here is what I came up. Unfortunately due to the small amount of travel on my tiny lathe it will be a huge PITA to mill out the fins. 20150307_150222.jpg
    So I am going to use the stock fan only I will drill a couple large holes in the sink so the fan blows directly on the fets rather than just on the HS. The top half of the sink does a better job of contacting the fets then the lower half so doing it this way should actually work out quite well. It has thermal protection so should it not be enough cooling it will shut down. But honestly between the water plate on the bottom and the hs/fan on the top it should be fine.
    Looking at the trackstar unit I should be able to do pretty much the same thing only with dual fans. The boat it will be going in can handle the tiny extra bit of weight. I just need to get my mitts on another SF cooling plate.
  14. #44
    Oct 2013
    la
    8,740
    If you need something made let me know. I also have a hydra 240 top that I milled the tube slots bigger for bigger tubing. It's still rounded.
  15. #45
    Jul 2011
    on
    557
    Thanks. I could do it if i really wanted. Just means milling so far and then undoing the vise and relocating the part to mill the rest. Its only a taig lathe so even setting it up for milling is a bit of a pain. I won,t do it unless I absolutely have to...
  16. #46
    9,402
    Very interesting...
  17. #47
    Jun 2011
    ct
    826
    have you guys determined that it,s the same as a castle 240? I need one. thanks
  18. #48
    Oct 2013
    la
    8,740
    Quote Originally Posted by urbs00007 View Post
    The innards are identical. You could buy an xl2 and put the board in your ice 240 case and be back in business.
  19. #49
    Jun 2011
    ct
    826
    are the red heatsink esc's same as the castle 240?
  20. #50
    7,630
    That was a good read.
  21. #51
    Oct 2013
    la
    8,740
    Just got through programming mine. Boats pretty much done.
  22. #52
    Jun 2015
    Fl
    54
    so I hate to revive a old thread but did you mods to the xl2 work and are they still working
  23. #53
    Jul 2011
    on
    557
  24. #54
    9,402
    Can this software be put on a memory stick and installed onto a PC with no internet connection?
    I've tried and it will not install. It is possible my home PC is messed up regarding USB before I installed the Castle software on a stick.
    Does the PC or laptop need to be connected to the internet to install software?
    Thanks...
  25. #55
    Jul 2011
    on
    557
    Should be able too as long as you have the dongle thingy to connect it to your pc.
  26. #56
    9,402
    OK then my software is corrupted on the stick and my pc has an issue in device manager. I accidentally deleted something to do with USB in devices.
    I'll have a PC hooked up where I am now soon. I'll D/l the software then and see if it will install.
  27. #57
    Oct 2008
    9,488
    Travis, have you picked one of the TrackStar 200a esc ?
  28. #58
    Oct 2013
    la
    8,740
    I haven't. Iirc the price isn't much difference and I prefer to have the real thing. Plus I like the castle data logging the best out of all the other names I've used. I guess stick with what I know kind of thing. I have one I'm building for my replacement Rivercat build.
  29. #59
    Oct 2008
    9,488
    I noticed the TrackStar does not have a bec
  30. #60
    Oct 2013
    la
    8,740
    That doesn't really bother me any. I have a unwritten rule that anything I build that will be pushed hard always gets an external bec. I feel like using an integral bec helps heat things up a little more.
