Results 1 to 2 of 2
Thread: MEAN MACHINE Owners
    Jun 2013
    NV
    179
    Default MEAN MACHINE Owners
    Are you running a single motor. How many Mah total are you running in your boat? 4S or 6S? Run time? I have two 3S 5200 mah 45C packs. I also have two 6S 2600 mah 45C packs. Will 5200 mah give me 4-5 min run time with a 4082 1500KV and M445 prop?
    41" & 29" FE Aeromarine Sprint Cats, Quickdraw powered "Dollar Eater" 41" Insane Cat, 29" BL mod Graupner Cat, 24" Hydro, 29" OB Cat, BL mod NQD Tear Into Jet boat, 55" Scarab, JET SWEEP R/C pool skimmer Rescue Boat.
    Feb 2008
    GB
    2,731
    I run 4s 5800mAh in mine, on a hacker b50 10-11L (bought too many years ago to remember which), detongued x438, 5 minutes 2o seconds runtime. I have also run it on 8s 5800mAH, on a Neu 1521/2.5D, detongued x440, 5 minutes 20 seconds runtime. Both setups drew the batteries significantly under 20% at the end of a run, runs of 4 mins 30s would have yielded significantly longer battery life.
    It felt too heavy for the hull on 8s with the big motor and if I was to set it up again without the constriction of rules I would go for an in between setup of 6s1p 5000ish mAh, 3674 1500kv, detongued x440, if you are after 4-5 minutes on 4-6s 5200mAh that is not enough power to warrant a 4082 motor and you would get very similar speeds but with more runtime from a smaller motor with lower io and less inertia.
