Results 1 to 16 of 16
Thread: Wow, didn't know the Lucas Oil could go so fast in (nearly) stock trim!
    Aug 2014
    262
    Default Wow, didn't know the Lucas Oil could go so fast in (nearly) stock trim!
    I've been busy with my Genesis for the last couple of months and decided to take out my Lucas Oil for a change.
    The boat is completely out of the box except I did replace the stock 1800kv motor with the UL-1's 2030kv unit. I added a OSE flexshaft and Octura x642 prop. On GPS, the boat consistently got 50 mph on 4S, using cheap old Turnigy 2S 5000mAh batteries!
    50mph, that just 10 mph less than my Genesis running a 40mm motor running on 6S! Temps were barely above ambient on 3 1/2 minute runs, just sweet running all around.
    Running my other 4S boats are typical depressing after a SAW run with my Genesis, but this Lucas Oil felt almost as exciting!
    Question - Is there a way to reinforce the hull of this boat without cutting up the double hull top? At 50mph, it did do a flip at high winds, and it did leave some very small fine hairline cracks on the top of the hull, probably due to the flexing.
    Jul 2010
    14
    412
    would like to see a video when you run
    Drammen rock City
    Apr 2010
    In
    324
    Yes they are fast. Mine with race set up and balance not to blow over run 47.8 with both the 2030 and the 1800. with different wheels. fast and fun stock
    beating amsoil boat. 1 race at a time !!!
    1,969
    A friend of mine upgraded his Lucas to 6S with a motor and ESC change here he is "poking" around...
    The config is a short Leopard 4065 1400kv with a seaking 130A HV ESC (I would prefer a standard marine seaking 180), on an octura x442 prop. It runs cool as a cucumber. The nice thing about the 4065 is that it fits under the canopy without any mods needed. I have the upgrade config covered in the Lucas setup guide, email me at jqhydro@gmail.com for a copy.
    Chief
    Jul 2010
    14
    412
    Man that's smooth. i sold my geicco last week, and soon as spring comes here, I'm getting the Lucas.
    Drammen rock City
    Aug 2014
    262
    Quote Originally Posted by maxmekker View Post
    You got it man!
    I should have her running this Saturday at my local pond, been unfortunately raining these last few weekends.
    Quote Originally Posted by skater368 View Post
    Did you did anything to reinforce the hull? I think flipping at that speed will results in those longitudinal micro cracks in the clearcoat or even the fiberglass.
    Chief
    Nice! I knew that the 3674 type motors don't fit with the stock mount because of the canopy, but the 4065 never occurred to me!
    I have converted my Revolt 30 to a Leopard 4082 2200kv motor recently, but I'm not sure about doing the same on the Lucas Oil. On the Revolt, I was able to easily reinforce the hull with carbon fiber, and adjust a new motor mount to lower the center of gravity for that big motor. But the Lucas Oil motor is so high on that double formed hull, that I worry about fitting a large motor in there, even if it clears the canopy.
    Aug 2014
    262
    Well, unfortunately last weekend my Lucas Oil flipped a couple of times rather hard at just under 50 mph and the hull on the left side cracked all the way though from bow to stern at the seam!
    The boat is supposed to be able to move at this speed I'm assuming, but apparently this hull didn't take it very well. I've seen plenty of Motley Crews crash at that speed with no damage, yet this Lucas Oil which is supposed to have slightly thicker glassing didn't. Oh well.
    I don't plan on cutting the tub up and fixing it from the inside, I will just use some high strength resin with some additional milled fiberglass to reinforce the seam.
    Mar 2013
    ny
    367
    the exact same place mine had issues ,not that big
    because i had removed the tub :easy fix
    but it stopped me from trying to pass the 80km/u ( 50mph) mark
    Oct 2008
    9,488
    What prop are you using with the 1800kv motor ?
    Apr 2010
    In
    324
    It was a 442
    Oct 2008
    9,488
    It was a 442
    Nice man
    what prop do you like running with the 2030kv motor ?
    thanks
    Jul 2010
    409
    An HV ESC is a better choice for 6S...
    Support US hobby suppliers
    Oct 2008
    9,488
    Placed one of these on order today !!
    Mar 2013
    43
    Could you post the setup guide?
    Oct 2008
    9,488
    Got my Lucas Oil yesterday !!
    hope to get it setup and try different props on Saturday
    1,969
    Quote Originally Posted by Arizonaheat View Post
    If you'd like a copy of the setup guide shoot me an email at jqhydro@gmail.com
    Chief
