Any suggestions for motor mount for the 1717 castle?
Thanks luck, really appreciate the responses.
So I ordered the ose.187 assembled cable for 3/16" props,
1/4" brass tubing, mono stinger, cf cloth, some lil things, and heading to pick up west systems 105/207 right now.... Boat should be here Monday!
What size turn fins did you use? Or recommend? Also your trims tabs? I think the speed master billet CNBC aluminum tabs are awesome. Looks like that's what you used as well correct? Thanks man
Yes those are the trim tabs indeed.
http://www.offshoreelectrics.com/pro...d=ros-spdt-502
The turn fins are the large
http://www.offshoreelectrics.com/pro...prod=ose-80066
This excellent build thread must be way above 10,000 view count were it not for the non-updating-status of the view counter. ()
Hull should be here any time! Anybody run the neu 1527? Can't decide between that and the castle 1717... Any input thanks!
The 1521 was plenty for this hull. A 1527 would be complete overkill. In fact the 1521 barely knew it has run. It really only got warm after s full run.
If you want to overpower it, the1717 is s great budget friendly choice. The 1527 is just more money, and pretty much not needed at all
Ok good to know, I was gonna spend the more money thinking higher price=higher quality. Did you ever get close to 60 like you were hoping, with the 1521?
Hull showed up! Was frightened when I saw the box damaged, but it's all good! Made it to Cali unscathed. Cf should be here any day, along with some hardware... Ordering motor and motor mount tomorrow.... Let's get this mother going! Still waiting for the sf 240 to be in stock, might look into other options if it's too long of a wait. Pumped though!
You know, I never gps it, but I'm pretty sure on the 448 I was hitting 60. I actually propped down to a 445 for sport running
The nue motor is def worth the money, but when it comes to 1521 or 1527, the 1521 was more than enough to send it airborn. Plenty of power
I used a sf 220 esc.
Start a build thread brosef. Be happy to see what you do man.
I have some extra amg logos if you want them. Dunno what you had planned
You bet, thank you for all your help, and your thread lit a fire under my %$&! I'll start a new thread too. Going to buy a new air brush this week, some thing simple and classy like yours I hope. Thanks again
No prob man!
Can't start new thread, I'll figure it out
Dave @ HRC builds mounts for the 1717 Castle http://hrc-mfg.com/ Dave is a awsome guy and a member of our club and a forum member. You'll probably have to PM or Email him.
Think I'm gonna follow the advice and go withy the 1521. What setup tho? 1.5d 1800 kv? Or? Sorry really noob with the boat setups, 8 or 5 mm?
The 1.5 d would be a good choice and a 448 maybe 450 prop on 4s.
The 1800kv also leaves room to go up to 5s if you want and move to a 445 or 447 prop
Awesome thanks you guys, and I did finally get a thread started also uploaded a picture. Look forward to sharing the progression with you guys.
Both at the same time. No dry time
Awesome that's what I wanted to here lol. Here goes nothing, pretty nervous, first timer. Thanks again you've been especially helpful.
It's easy bro. You'll do fine
