Results 1 to 13 of 13
Thread: 1 ESC 2 Motors
    Aug 2013
    Fl
    2,451
    Default 1 ESC 2 Motors
    Is there any reason you can't run two motors off one ESC, for instance a 240amp Swordfish pro plus with two 4060 tp 1860kv on 8s this combo will be in a Drag boat. So no long runs just short bursts.
    Va
    4,670
    I did it a long time ago with brushed motors ... not sure how it would work on a brushless setup.
    IMPBA 20481S D-12
    Aug 2013
    Fl
    2,451
    Quote Originally Posted by egneg View Post
    I think I'm gonna hook it up on the bench and see how it works, as long as both motors react the same it should work.
    Oct 2013
    la
    8,740
    Quote Originally Posted by flraptor07 View Post
    if not its going to be an expensive lesson.....lol
    Aug 2013
    Fl
    2,451
    Aw hell, what's the worst that could happen
    9,402
    https://m.youtube.com/watch?v=YpDGRLRFDNY
    https://m.youtube.com/watch?v=zeYAWqt2rIE
    I've seen it done on on Youtube with a T180 and a pair of T600 motors if I'm not mistaken. Does work to a degree but, one motor may start before the other and one might turn the opposite way on occasion too.
    Jun 2007
    1,515
    The esc will get confused with conflicting rotor position reports from two sources.
    Aug 2013
    Fl
    2,451
    Quote Originally Posted by RayR View Post
    Wouldn't that be on sensored motors?
    Jun 2007
    1,515
    You are correct, sorry.
    US
    5,557
    It works, a member here tested with up to 4 motors several years back and posted it, vids are on youtube. Amp draw will be your main concern
    US
    5,557
    Here's one of his vids:
    US
    5,557
    Here's one of his that is more technical, hooked up to a computer and has the motors under load he tests thrust etc.......
    1,711
    ReddyWatts fleet photo
