Alien 400 amp Speed Controller - virtually new SOLD
This ESC is a monster.
It has 6 mega capacitors of 100v, 330mf, 8mm connectors direct soldered on the PCB, battery spark suppression wire, double water plate cooling system, powerful Mosfet, USB link to program it.
Specs:
Size: 165 x 55 x 35 – Weight: 650g
Battery voltage from 4S to 24S.
Simply set function value by Pro-Box, by PC via USB kits or by trasmitter.
Two way communication while connecting it with computer.
Firmware will be upgraded automatically.
LVC
Timing settings may be adjusted (0°- 30°)per degree to suit the motor type
3 types of throttle curve
3 types of acceleration control.
Motor rotation programmable.
Auto cut off power within 3 seconds in case of signal loss.
Function Value:
BATTERY TYPE:Ni-XX、Li-XX
NUMBER OF CELLS: Auto,2,3…
LVC: programmable
PWM frequency: 8 – 16 – 32
FORWARD POINT:Auto、fixed 1.0mS、fixed 1.1mS、fixed 1.2mS、fixed 1.3mS、fixed 1.4mS, fixed 1.5mS
REVERSE POINT:Auto、fixed 1.7mS、fixed 1.8mS、fixed 1.9mS、fixed 2.0mS
MOTOR POLE N°:motor poles number, 2-4, 6-10, 12-14 (HELI ONLY)
THROTTLE CURVER: Logarithmical、linear、Exponential
ACCELERATION: Soft / Medium / Hard
TIMING MONITOR:On/Off
DELAY TIME FORWARD TO REVERSE: MS (CAR/BOAT ONLY)
PWM LIMIT: 0N/OFF (CAR/BOAT)
MODE HELI: CONSTANT RPM/NORMAL (GOVERNOR MODE)
CURRENT LIMIT: AMP (CAR ONLY)
ABS BRAKING: % (CAR ONLY)
MOTOR TIMING DEGREES: 0°、1°、2°、3°、4°……30°
ROTATION:Left/Right
REVERSE: ON/OFF (CAR/BOAT ONLY)
Some history;
I bought this for my speed run endeavors with the R/C Bullet. However the brake profile was not strong enough, even at 10mph in the street. As a result - this esc is virtually brand new. It also comes with a 5 capacitor bank and a USB programming stick. Bruno at Alien was very helpful in the set-up procedure. Currently , it is set as car esc - but the brakes can be dialed to disable. Oh - and the reason I purchased the boat version was because I was planning on pre-cooling the esc via circulating ice water - ala straight-line style.
Fitted with Castle 6mm bullet connectors.
http://alienpowersystem.com/shop/boa...sfet-esc-hv-2/
All this for $190 shipped to the lower 48 states
shipping to Canada will have to be calculated.
N
