Due to being accused for slinging BS in the News Years Resolution thread I figured I would further clarify what I have found and experienced with my boat set ups. I could care less about the accusation, but thought maybe some of you that have difficulty with heat issues may find something here beneficial.
I will say again, I do not generate very much heat at all with my open power setups and I have had pretty good control with my P-Limited set ups. Why?
My power set ups: N2 Mono (nats offshore winning boat) - The motor is a Lehner 1940 4 turn and a 2P setup. The motor mass size is similar to the 2030 and the TP 3630. Most would consider this motor mass size to be conducive for 4S. I consider it a 2S mass size motor. P-Mono - This motor is a Lehner 2260 5 turn and also a 2P set up. Most would consider this motor mass to be conducive for 6S. I consider this a 4S mass size motor. Motor mass dissapates the heat. Spent two years testing and burning motors to find this after lipos came out. The tricky part of going up a size with motor mass is finding the right KV so you can still get close to 30,000 rpm to the prop.
P-Limited set ups. IMO the 36 diameter by 55-65 length motors that are supplied by the vendors in the rtr offerings are insufficent for 4S. The mass is not there. IMO - bad engineering. With the right wind this mass is good for 2S power. And of course some decided we should use these for a fuse. I guess.
So for under massed motors in a P-Limited set up what do you do. Large aluminum motor mount. Good water cooling - dual lines. Short .150 flex installed perfectly. Ball bearing strut. Very sharp and prepped prop. The tricky one - set the boat up loose.
These building methods have kept my P-Limited set ups from exceeding 100 degrees. Not counting the current 2030 issue.
Maybe there are a couple ideas here a couple of you guy's could utilize. Feel free to contact guys I race with for verification.
Doug
